The Check Engine Light came on in my 98 S70 GLT. An OBDII scan revealed a P107 error code.
Anybody have any experience with this and thoughts on how this maybe fixed ?
Thanks in advance.
-aj98s70
CEL On - P107 code
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
P0107
Volvo specific code list: Athmospheric Pressure sensor.
Generic code list: Manifold Absolute Pressure/Barometeric Pressure Circuit Low Input.
Maybe MAP sensor?
Maybe MAP sensor?
Guest
I know this is an old post, but I'm wondering where this sensor is. I'll keep looking but if you know could you let me know. Thanks.
It is on the right hands side inner fender behind the headlight! I believe it is called a noise sensor. I had the same problem on my 1998 S70 GLT. It is mounted on a metal bracket. I removed mine and cleaned it with Carb cleaner then gently dried it with compressed air. Hanot had the code sense.
Marty
Marty
- 541 Views
Last post by fiore67
- 946 Views
Last post by iruleyounow
- 2168 Views
Last post by Craigd2599
- 2084 Views
Last post by cuhfs
- 12 Replies
- 5136 Views
Last post by mrbrian200
