1998 S70 Lack of Power
RobF
- Year and Model: 1998 V70, 2004 XC70
My 1998 S70 with 370000 km runs smoothly but will not rev above 4000 rpm and has a very little power. I have checked the timing belt, compression ( 180 psi in each cylinder ), spark plugs and throttle body and all seem to be working correctly. I have not changed the fuel filter yet but I wasn't sure if this would cause this type of problem. A friend suggested a plugged catalytic converter which improved things when I took the car for a short drive up a steep hill with the Cat disconnected from the exhaust manifold. I am wondering if this does make sense and if the only solution to the problem is replacing the catalytic converter? Thanks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I hope this makes sense...if it is just clogged but still functioning it will not throw any codes but will result in a huge loss of power. If it's just not doing its job actually converting the exhaust, then it will throw codes for the rear O2 sensor.
One quick test is to kick or smack the bottom of the converter...if you hear something that sounds gravelly inside, it's dead. If you can get it to rev over 4K with it disconnected, and feel more power...then that's also a sure sign it needs to be replaced.
'98 S70 T5
2016 Chevy Cruze Premier
RobF
The only code I get is PO413 which I believe is related to the air pump which hasn't worked now for several years. I take there is no other solution other than replacing the catalytic converter.
- Year and Model: Many Volvos
- Been thanked: 76 times
Check your Intercooler lines. They can rub through on the underside or a hose clamp will come loose and the boost will get killed along with un-metered air to the intake.
- 2380 Views
Last post by carboncow
- 1190 Views
Last post by juggernaught_666
- 1313 Views
Last post by misha
- 1773 Views
Last post by yanga001
- 11 Replies
- 1988 Views
