Need help Identifying Part I need
Leatherneck
- Year and Model: 2006 XC70
I have a 1998 Volvo S70 GLT. If you are looking at the engine, (standing in front of the car). On the right hand side just beside the fuel rail...there is a black plastic cover you can remove with a phillips head screw driver (Just one screw holding it). After removing the cover there is a hose that bends and is 1 inch on one end and 1 1/2 inch on the other. It is 4 inches long. Not sure what it is connected to but air runs through it. I need to replace this part as it has a huge hole in it but i'm having problems finding it on FCP Groton. If Anyone can help me out I would appreciate it.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
It could be part of the idle air control system, but can you take a picture of the part and post it?
- Year and Model: Many Volvos
- Been thanked: 76 times
I think jreed nailed it. Does it go to a silver cylindrical object (the IAC valve) that is mounted just below the throttle body? If so or if you can post a picture I will look up the part number for you.
Wrapping the line with electrical tape will likely keep you going while the part comes in.
VolvoTurbo850
- Year and Model: 1994 850 (T5)
agreed i think it is the air idler
www.fcpgroton.com/category-exec/category_id/154/nm/Fuel_Injection/sub_top_menu_item/by_make-by_model-by_year/by_make/78/by_model/1161/by_year/48
If you dont see it on their web site (the hoses) ask them .. they always can order it for you.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
Leatherneck
Yes, I believe that is it then. I'm working so can't post a pic right now but that's exactly what it goes to. Thanks!
- 12 Replies
- 2649 Views
Last post by rspi
- 1600 Views
Last post by user17600
- 1062 Views
Last post by alschnertz
- 1881 Views
Last post by PaddyM
- 740 Views
Last post by olundy673
