Hello all,
Proud owner of a 1998 V70 2.4L auto, 197km. Just replaced the cabin filter; $30!!!
Is there a commercially available washable cabin filter? Or is this something I have to make myself?
Faz
Washable cabin filter?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Not aware of a washable, but a non-carbon shouldn't run you more than about $12-15 and a carbon filter from a discounter should be about $22. Change every 15K mi.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
NoMechanic
- Year and Model: 2004 S60 Turbo
Ignorant on the subject... I have not replaced mine in about 45,000. I thought it just filtered the air. We are not smokers and live in a rural area - is this an important maintenance item?
- E Showell
Yep -- Pretty important. I am advised (but have no way of verifying) that failure to change this filter regularly can lead to failure of the a/c evaporator, which is a very costly repair if left to a professional and a very time consuming one if done DIY because, I believe, it involves removing the dashboard.
I believe the carbon one will filter pollen as well. If you are in a rural area and have allergy sufferers in the family, this might be an important consideration for considering the carbon filter.
'95 855 auto (sold)
'95 855 auto (sold)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
A washable one doesn't exist that I know of - but I bet you could create a washable one yourself - they have washable indoor & shop vac filters; just dissect one of them, cut out the old filter material, and fit it to your car's filter.
There are worse things you could forget about, but changing it out every now and then could make your nose (and maybe the blower motor) happy. 15,000 miles is a bit overkill - that's about 6 months for me, but I'd probably change it about once a year - especially after all the stupid pollen everywhere in the spring.
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I actually have a different theory. I think failure to change the cabin air filter is actually beneficial in prolonging the life of the AC evaporator, while not so for the blower fan unit.
My AC is still going strong after almost 11 years and a lot of use, and I think that is in part due to the fact that the cabin filter was replaced only twice in the car. The more the filter is clogged, the better it filters = the less crap gets down into the AC. I do think that this can lead to the early death of the blower fan though. My fan is making strange noises from time to time and I am thinking it's on it's last legs. But as far as I know, my AC evap has no leaks. I tried recharging it one time because I thought I needed to, but it pretty much took no 134a.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
MarinerMan
- Year and Model: 1999 V70 N/A
- Has thanked: 6 times
- Been thanked: 10 times
I know this is resurrecting a dead post, but do you have a part number for the purolator filter?thecheat wrote: 13 Sep 2010, 16:54 I bought a purolater from Pep Boys for $17, but i had to coerce it into fitting and making a good seal.
- Has thanked: 1613 times
- Been thanked: 4075 times
MarinerMan….if you get the Volvo or Mann filter from FCP you can send it in with your oil filter for credit every year.
F Sea P for you.
F Sea P for you.
MarinerMan
Oh goodness that’s right. I have a whopper of a credit for them right now. I didn’t think about that. Thanks again Doc!
- 2143 Views
Last post by stephansvolvo
- 14 Replies
- 5911 Views
Last post by V70r carbon
- 1275 Views
Last post by rspi
- 3909 Views
Last post by BEJinFbk
- 2013 Views
Last post by MadeInJapan
