Coolant: how to measure ratio water-coolant
dejongmc
Year and Model: 2004 Volvo S80
Post by dejongmc »
Due to a little leak I had in one of the hoses from my cooling system, I added purified water or Zerex G5 to it, but by now I do not know if I have the right ratio of 50%-50% anymore.
Is there an easy way to measure the water-coolant ratio?
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
Retired MVS Contributor
Post by Retired MVS Contributor »
There are inexpensive hydrometer type tools for measuring that available at Autozone, Autobarn, etc...It measures the specific gravity...
nightc1
Year and Model: 99'V70 Base 140K+Mi
Post by nightc1 »
Yeah an anti freeze tester tool is the best one for the job. It'll tell you what temperature your car is good for. 50/50 is ideal but not a diehard requirement. Colder climates may require closer to a 60/40 (Coolant/Water) blend. Most stores have testers for $1 to $3 with the $3 one looking fancier but doing the same job as the cheaper ones.
As a side comment, in the future... pre-mix for adding coolant/water. You can buy antifreeze that is already 50/50 mixed, or mix anti-freeze in a separate container with distilled water that has a clearly defined 1/2 way point. It doesn't have to be perfect or anything... but if you are adding to a system that already had the stuff mixed up really well... then you lost the mixture of ~ 50/50 and your current mixture ratio is still ~ 50/50.
A 50/50 mix has freeze protection down to –34°F and boil-over protection up to 265°F . I'm saying that so if the tester only shows the temperature it's good for and not the mix % then you can see an approximate target.
