Can anyone tell me how to reset the "Time for Regular Service" light on my 2002 S60 T5?
Thanks.
Resetting Service Light on S60T5
rslelf1111
Try this.....I found it under the S80 information. Maybe it will work!
All models for 1999 and on can be reset by putting the ignition key into position I, push in and hold the odometer reset button (use your left hand), move the ignition key to position II, when the service light begins to blink,let go of the odometer reset button. Confirm by turning your Volvo off then on again.
brianf
- Year and Model:
I got this off another Volvo forum and it works!!!!!!! The timing is the answer. I was trying the other methods but doing it too slowly check this out!!!!!!!!!
Here it is for all you guys who are proud Volvo owners s60 years 01-03 maybe newer cars too.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
-Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II
-The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
-Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
-Ignition position II.
Note! Turn the key to position II within 2 seconds.
-Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
-Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
-If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
- 871 Views
Last post by warmblood58
- 872 Views
Last post by phils94850
- 1216 Views
Last post by fields 100
- 424 Views
Last post by Bill1959
- 276 Views
Last post by foggydogg
