Does anyone have recommendations for types of plugs? The prices vary online from $4.95 a piece to $18.70. Is there really that much of an advantage in getting the more expensive plugs?
Should I replace the plug wires cap and rotor?
Tuneup for my 93 850
jamesspringer
- Year and Model: 850 GLT, 1993
Thanks. NGK plugs are only $2.29. That sounds a lot better
- Year and Model: Many Volvos
- Been thanked: 76 times
On a N/A car I run Bosch coppers, they are even cheaper but it is critical that the gap be 0.028 and error to the low side when gapping them. They are under $2.00 each but you can normally only get them at NAPA. They changed numbers recently but they used to be FR7-DC and I have not committed the new number to memory yet. Out of the box they will come gapped closer to 0.035 to 0.040.
Avoid like the plague the Bosch +2 or +4 platinum plus plugs that you can't gap. The car will never run right with them installed.
I like my +4 Platinum Bosch Plugs didnt like the £12 each though
NGK made my T-5 run badly odd how there is such a difference from the USA and UK Spec
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
Copper only
Bread clip fix, EST catback, IPD SR5T, MSD coil, Bosch cap and rotor, OEM plugs/wires, silicone hoses, VDO gauge, new antenna mast/leather wrap/rotors & pads, IPD wind deflector, IPD poly bushings, IPD HD CBV, IPD turbo seal, IPD cabin filter
jamesspringer
Thanks for all the replies. I priced actual Volvo plugs at $30.12 for a set of five from a dealership but the closest dealership is an hour away. I think I will try the NGKs first.
Next question: How important is it to get the torque right? The manual lists the correct torque at 18.4 ft. lbs +/- 3.7 ft. lbs and says to "use the correct torque". I have never needed to torque a plug before and don't even own a torque wrench but then, I have never worked on a Volvo.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It doesn't matter. Spin it in hand-tight with the wrench, and then tighten it down a bit.
NGK's should work just fine, just make sure to set the gap!
'98 S70 T5
2016 Chevy Cruze Premier
jamesspringer
Well, I changed my mind at the counter and went with Ozark Lee's suggestion of Bosch Coppers (Bosch Super Plus copper core plugs, Autozone cat. # 7955). They came pre-gapped to 0.033 to 0.036 so I think those were what you were descibing. I gapped them at 0.028 (perhaps a shade less on some - between 0.027 and 0.028) and I'll update after I install to tell you all how it worked. Thanks for the help.
jamesspringer
Well, it idles a bit better but still sounds a bit rough. Power is improved somewhat as well. Any other suggestions? It sounds like a sort of rythmic clunking that smooths out at higher rpms. How do I check if the timing belt is worn? Could a clogged fuel filter or dirty injectors be the culprit?
- 13 Replies
- 2943 Views
Last post by echase76
- 18 Replies
- 5378 Views
Last post by Ocelot
- 21 Replies
- 2802 Views
- 4748 Views
Last post by tryingbe
- 718 Views
Last post by shaker_chi
