98 S70 2.4l N/A 164,000
3 days ago my car was idling around 1200 after fully warm. I gave it a rev to see if it would drop and a big white cloud shot out the exhaust. The next day it idled a little lower, then dropped to normal (900).
Hasn't done it again so far.
Things I've replaced recently:
Entire PCV system
MAF (used)
Upstream O2 sensor (OEM)
Plugs, Wires, Cap, Rotor, Coil, K&N Air filter
Thermostat
I have a couple vac elbows in need of replacement soon. Could that be it?
High idle, white smoke
xtrattitude4u
- Year and Model: 1998 S70 2.4l N/A
How long ago did you replace the PCV ? The engine might be burning off any condensation built up in the engine. Check to see if you have any engine codes from around the MAF or O2 codes and of course check to see if you have nasty white gloop under the oil cap
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
xtrattitude4u
The PCV was done like 6 months ago, so I don't think it's anything to do with it. Have been checking the oil constantly due to coolant loss, and theres no goop or anything strange. turns out it was the heater core.
I think the high idle may not be related to the smoke. Yesterday it was idling perfect, but still the smoke.
My car does have 165,000 miles on it, maybe the smoke is just valve guides.
When I changed my spark plugs last, I noticed MUCH oil under the ignition cover. Is this a clue?
Any suggestions would be great. I am a novice self-mechanic and will test anything you guys suggest.
I don't have a check engine light on and haven't for awhile.
xtrattitude4u
I have cleaned my IAC thoroughly and adjusted the throttle cable.
Although the throttle is more responsive, the car still idles high sometimes.
The problem seems to be getting worse: it will now rarely idle normally after being warmed up and driven.
The idle seems to fluctuate from day to day. It will be at 1200 some days, 1050 at others, and around 950 when it's being good.
It will idle at 900 a couple minutes after starting, but usually it will idle high when parked after driving awhile.
It idles at a normal 900 when in gear.
Please let me know what are the next thing(s) I need to check.
Thank you
Thank you
xtrattitude4u
I have thoroughly cleaned the MAF with MAf cleaner and replaced some vac elbows and and caps.
Still idling high.
The only ideas I have left are to pay the stealership to test my MAF and do a smoke test on the vacuum system.
I would probably be too broke to try much else after that for awhile.
I've recently replaced:
Plugs, wires, cap & rotor, Ign coil, Fuel filter, Fuel pressure reg,
PCV system, front O2 sensor, MAF (used)
As you can tell I've replaced most everything I can think of.
Still idling high.
confused_al
- Year and Model: 1996 TLA wagon
There is a remote possibility that your intake manifold is leaking a bit, not b/c cracked manifold but around the gasket. That would caused high idle issues. You mentioned you did PCV earlier, did you torqued all the bolts?
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
Have you done a compression test just to make sure it is not a head gasket? The smoke could be either a head gasket or bad turbo seals. I have not seen guide seals going bad at 165K but I guess it is possible.
xtrattitude4u
Non turbo. I have done a compression test and all cylinders were within 2psi of each other so that looks good.FCPGroton wrote:Have you done a compression test just to make sure it is not a head gasket? The smoke could be either a head gasket or bad turbo seals. I have not seen guide seals going bad at 165K but I guess it is possible.
I think I found my problem. While sitting in the drive thru I put my foot under the gas pedal and pulled it back a little.
Idle returned to normal. I think I just need to adjust it.
Ive already adjusted the plastic nut on the throttle, were would I adjust the pedal?
As for the smoke, I'm still not sure. It's a very intermittent problem, only showing up a couple times a week.
xtrattitude4u
Well it seems I have two problems, When the idle is 1200 it will only drop to 1100 (or not at all) when i pull up on the pedal.
I love my Volvo, but I don't think it loves me!
xtrattitude4u
The smoke went away after a Seafoam treatment. It also made my car run better.
The high idle however, remains.
- 14 Replies
- 1166 Views
- 2023 Views
Last post by Ben850
- 1593 Views
Last post by precopster
- 13 Replies
- 1972 Views
Last post by misha
- 384 Views
Last post by martinbarn
