i could use some advise
I'm not sure what part to buy from fcp groton or if i should get the headgasket kitfrom some where else any help would be apriciated
2000 v70 xc se headgasket set
Upcoming Fuel Pump recall
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
VolvoTurbo850
- Year and Model: 1994 850 (T5)
I have done my head gasket though FCP and almost 12,000 miles or 20,000 km later I have had no issues.
I believe that Elring is the OEM supplier and that kit i purchased had everything i needed to rebuild the top end and was cheaper than purchasing separately including cam seals, valve top seals, exhaust man. + intake man. on and on.
I also replaced the hold down bolts.
While your at it you might as well replace the thermostat, timing belt, pcv and clean out your EGR if so equipped.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
mrjacobrussell
I noticed there seams to be two different head/cam tool sets as well.
Does any one know if I have to buy the all black one or if the cheaper black and red one will work ?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
VolvoTurbo850
did you mean the cam hold down tool?
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
mrjacobrussell
Yeah I noticed on ebay there is a cheap one and a beefy one. I was afraid the cheap one wouldn't work on my wifes 2000 v70. It has the adjustable cam timing and coil on plug
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
VolvoTurbo850
believe it or not you can make your own with some angle iron and a drill machine.
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
mrjacobrussell
there are differences in the tools, obvious differences.
any opinions on the tools ?
does any one know if one will not work on the 2000 v70 xc se (coil on plus and variable cam timing)
- this tool ranges upto 500 dollars
- tool1.jpg (40.9 KiB) Viewed 2140 times
- this one is around 200 dollars
- tool2.jpg (21.13 KiB) Viewed 2140 times
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
clarkandrew45
- Year and Model: 2008 Volvo S60
have you already figured out what part will you buy from fcp? Have you called them up?I also called them last week for a gasket kit.mrjacobrussell wrote:i could use some advise
I'm not sure what part to buy from fcp groton or if i should get the head gasket set from some where else any help would be apriciated
mrjacobrussell
I ordered the head gasket set, bolts , silicone and a few ods and ends... I figured the gasket set would come with the intake cam plug it didn't though :/
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
- 1418 Views
Last post by alschnertz
- 2295 Views
Last post by jonesg
- 22 Replies
- 2526 Views
Last post by erikv11
- 286 Views
- 703 Views
Last post by rspi
