1995 Volvo 850 GLT driver seat belt stuck
Southern80
Year and Model: 850 T5
Post by Southern80 »
Hi you all!
Two day ago the SRS light went on shortly after taking a curve , and yesterday did same thing. Today my driver seat belt is stuck and can not release it. Does anybody experienced similar trouble?
How can i solve it?
Thank you for your help.
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
remove the plastic panel from the side of the car and check that the seatbelt tensioners haven't fired if they have you will need new ones if it's not those it might be a coin thats dropped into the mechanism but chances are the seatbelt tensioners have fired
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
agreed if your srs light went off it is part of the restraint system which tensions the seat belt when you are in a collision usually!
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
