Okay.... I hope it's not the Rear Main Seal.... To help me narrow down the location of the leak in my 17 year old daughter's car....
1. It just started leaking 2-days ago.
2. It's not "shooting oil" so I do not think it's oil under pressure.
3. It does seem to be isolated to the back of the the engine.
4. When the engine is hot oil "smoke" is rising from the "exhaust" area
a. so it's either burning on the exhaust manifold or turbo housing
If you were here.... what locations would you suspect? Thanks so much. If you ever need to R&R a fuel pump.... I'll walk you through it. https://www.matthewsvolvosite.com/forums ... =1&t=20367
XC70 Oil Leak
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Clogged PCV system or bad oil cap seal. The rear cam seal (behind the dist cap) may be leaking too if there is lots of oil everywhere.
I'm pretty sure if you take off the spark plug cover on the top, the wells underneath will be covered in oil. That then runs off the back onto the turbo.
'98 S70 T5
2016 Chevy Cruze Premier
mindshadow
- Year and Model: none
Which side of the engine is most of the oil coming from? I had a huge puddle on the passenger's side and it was a combination of the PCV and a few seals (camshaft and exhaust I believe). If it's the driver's side you may want to panic a tad.
- 323 Views
Last post by BlackBart
- 1422 Views
Last post by t3yf5g
- 1417 Views
Last post by mrscullini
- 3144 Views
Last post by Stephen0523
- 1443 Views
