Now What? - XC70-Post PTC Cleaning
SniperCat
- Year and Model: XC 70 1998
- Been thanked: 2 times
I just replaced the rear cam seal (under the distributor cap) and cleaned out the PTC valve. Car ran great for my daughter and the oil leak is gone. I repaired last night. She drove the car to school for her a.m. classes and it drove fine. When she got home at lunch I inspected for oil leak and it wasn't there. So..... I cleaned the engine (with the spark pluc panel removed) with some Simple Green and then rinsed it off. Now the vehicle seems to be running on only 4-cylinders. I don't have a code machine.... any ideas????
Reason: Removed extra question marks.
You probably have water under the spark plug boots. that will mess things up big time and won't evaporate for a while.
1998 volvo v70 non-turbo 140,000
I go to the junkyard to practice future repairs.
SniperCat
That's exactly what I thought.... so, on the second boot I go to remove.... blammo.... the cord ripped right off the top of the plastic right under the boot. So I now have to get a spark plug wire kit. Off to O'Reilly's ($40 less than local OEM and included the coil wire). After R&R the wire kit... runs great. Thanks folks. If you ever need to R&R a fuel pump.... look me up
- Year and Model: Many Volvos
- Been thanked: 76 times
If the local O'Reilly has a wire kit that actually fits it will get you by but the car won't be happy unless you replace them with the OEM Bougicord wires.
Been there, done that, got the additional bill on the credit card.
- 14 Replies
- 2560 Views
- 1041 Views
Last post by kahl
- 11577 Views
Last post by Sveedy
- 1334 Views
Last post by 98v70xc206
- 840 Views
Last post by G Martin
