ABS module - - needs programming?
TipTopTommyT
Year and Model: X/C V70 - 1998
Post by TipTopTommyT »
It appears my ABS module is bad...the TRACS and ABS light come on every so often. My mechanic says that in addition to the part costing $300+, I may need to spend another $200 for "programming". I have no idea what's involved but does that sound right?
Yeah, I know there's a guy on the board that rebuilds these things but I'm wondering about the programming.
Thanks.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
What? No. Not on a '98. It just needs to have the contacts resoldered, and then both of those lights will go away.
'98 S70 T5
2016 Chevy Cruze Premier
TipTopTommyT
jablackburn wrote:What? No. Not on a '98. It just needs to have the contacts resoldered, and then both of those lights will go away.
Ok, that's good. I can live with that.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
1996-2001 if you can't do soldering yourself...
$100
www.modulemaster.com
Tell your mechanic to take the module and shove it you know where!
He obviously knows nothing about Volvos
TipTopTommyT
Thanks JRL....will the braking system be affected if I drive without the module while waiting for the rebuild? I'm sure the ABS and TRACS lights would light but that's no biggie.
jblackburn
You won't have ABS, but standard brakes, and you also won't have a speedometer.
If you have a GPS unit, most can function as a speedometer while you've got the module out.
'98 S70 T5
TonyMastodon
Year and Model: 98 V70R
Post by TonyMastodon »
Talk to Matty Moo... I bought a rebuild from him with very fast shipping (3 days) and will answer a lot of your questions on the phone.
Cant go wrong with Matt.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
^^^ As far as I know, he's currently the least expensive. Haven't heard any complaints.
Also -> Amazon link
twncty
Year and Model: 1999 V70 XC AWD
Post by twncty »
Matty Moo is the only way to go! Once you install the module make sure you erase the codes and the lights will go off. I stopped at Advance Auto Parts and used their diagnostic code reader to check and erase them for free.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
No! You don't need to clear the codes.
They will clear immediatelly when you go to a test drive after reinstalling the module.(If resoldering was a success).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
