Temp gauge up and down
evegreen
- Year and Model: 1999 V70 XC 2.4L
Yesterday when driving my temperature gauge went right into the red for no reason. I was two minutes from home so now it is parked. I had noticed a month or so ago that a whining seems to be coming from the serpentine belt, it had used up a lot of coolant in August and the air conditioning had stopped working. In the drive way this morning I turned it on and it is reving high and low and the temp gauge goes up and down with the revs. Car has 152,000 miles, please help.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The whining and fluctuating RPM sounds like it could be your alternator has gone. You can test the voltage on it to be sure.
At the same time, get up under it and see if the water pump is leaking. Or does the exhaust smell particularly sweet? It shouldn't be eating coolant unless it's either leaking somewhere, or the headgasket has developed a leak.
'98 S70 T5
2016 Chevy Cruze Premier
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Your thermostat is probably stuck in the closed position causing the car to overheat.
If your temperature gauge is going up & down when engine is reving itself,then your ect(electronic coolant sensor) is bad.
Replace both of them,you can put aftermarket thermostat in your car,like Vernet,but your ect sensor MUST be the oem one if you don't want troubles.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Are you referring to the engine coolant temp sensor located under the thermostat housing or is this something different?misha wrote:Your thermostat is probably stuck in the closed position causing the car to overheat.
jblackburn
That's the one.
'98 S70 T5
- 1367 Views
Last post by FLXC90
- 128 Views
Last post by Grantkat
- 6475 Views
Last post by 93Regina
- 622 Views
Last post by paul850
- 1172 Views
Last post by alschnertz
