Picture of a "Yellow Bulb" iluminates on dash
bronxnativ
Year and Model: 96 850 GLT 5 Speed
Post by bronxnativ »
I checked the forum, but nothing is listed, so hopefully someone can help me with this:
Each time I press on the brakes, A yellow light with a picture of a light bulb illuminates. Anybody know what this means???
I have a 95 850 GLT, non turbo.
Thanks!
Al
icelandic
Post by icelandic »
It means one of your brake light bulbs is burned.
1995 859 auto NA
bronxnativ
Thank You Icelandic!!!! I was pulling my hair trying to figure this out. I thought maybe it was related to the brake fluid level. Again, I appreciate your reply!
Al
icelandic
Post by icelandic »
That bulb will iluminate upon steping on the brake whenever one of the brake lights is burned. If it iluminates continuously when you have the beams on, it means one of the running lights is burned (might be the beam bulb or the corner light bulb)
Good luck!
1995 859 auto NA
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Even one of the high mounted 3rd brake light bulbs burning out will trigger the fault light.
When it comes to brake lights, tail lights, and headlights I always replace them in pairs or in a set in the case of the brake lights.
When one goes the other usually isn't far behind.
bronxnativ
Thanks Lee. Appreciate your input also!
Al
