My automatic ECC recently stopped working completely. I pulled up the DTC's from the self-diagnostics, and this is what I have:
211: driver's side damper motor position sensor shorted or open circuit
321: driver's side damper motor active too long
323: ventilation damper motor active too long
411: passenger compartment fan overcurrent or seized
414 and 417: driver and passenger side temp. sensor intake fan seized
I just want to see if anyone out there has any experience with any of codes and resolving their respective issues. I've drawn the conclusion that the first 3 codes are probably related due to the sensor issue.
Thanks.
'95 850 ECC
- Year and Model: Many Volvos
- Been thanked: 76 times
Start by clearing all of the codes and see what comes back. The ECC is like an elephant - it never forgets any error it has ever had unless it gets cleared.
The 411 is the one that likely killed the system - that is the main blower fan.
https://www.matthewsvolvosite.com/forums ... 39#p119939
Try this too. I had an issue with my ECC, and It threw a bunch of codes. This was the fix for them all.
93 850 GLT sedan 156K
94 850 Turbo 189K
94 850 Turbo 189K
Well, I tore into it this afternoon. I think the blower motor had seized up - I took it out and hooked it to the battery and it ran, and after re-installing it, everything else worked without any issues.
Thank you all for your suggestions.
- 1030 Views
Last post by xnRS
- 4955 Views
Last post by CRM
- 368 Views
Last post by AlanHMultiV70s
- 391 Views
Last post by combatkarl
- 1528 Views
Last post by Ben850
