squealing and high emissions
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
pottypaula
Year and Model: 440 1993
Post by pottypaula »
A couple of weeks ago my car started squeeling. It would only last a few minutes. Last week my car started to overheat even on short journeys. The temperature guage would shoot up to the red. So I'd pull over turn the engine off. After waiting for the car to cool down I'd start the car but it wouldnt start, as if the battery is dead. So I'd have to wait a bit longer, then it would start fine. I have now noticed I have a water leak. The water pump was replaced last year. It now squeals all the time.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
It sounds like the water pump has committed suicide. What kind was it replaced with? Some replacement parts are very cheap and have a high failure rate among Volvos - I've had a few go bad within months on me.
'98 S70 T5
2016 Chevy Cruze Premier
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Where is the coolant leaking from?
Is the drive belt adjusted correctly? If not that will squeal and affect the cooling system.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
pottypaula
Water pump replaced. Drive belt fine. Still squeals. Nearly all the time now and a lot louder.
billofdurham
How old is the belt? As they age they leave a coating of rubber on the pulleys and this can cause a squeal.
Bill.
Previously:
pottypaula
No idea. But its now the least of my worries. Car failed MOT on emmisions. The Mechanic said not a problem it can be fixed by adjusting the c.o. potentiometer. But he couldnt find it. Looked in Haynes manual, not where they said it is. Mechanic came to the conclusion that I cant have a 1.7 engine. Some previous owner must have changed it to a 2lt. I tried to look for the engine number but couldnt find the one on my owner docs. The number I did find has 1 letter and 6 numbers. My doc says 1 letter 12 numbers. Can the Mechanic be right? Am I looking in the totally wrong place for the engine number? Thanx for your help
pottypaula
Drive belt was replaced along with the water pump. Got the engine type sorted. Just leaves the high emissions. No point sorting squealing if it wont pass MOT
yuckuJackD
Year and Model: XC70; S80; S40
Been thanked: 2 times
Post by yuckuJackD »
!!!SPAM!!!
Just to make you feel better:
My mechanic said: "Oh, its a renault! If there is not oil and other liquid outside so there is not inside, too (it's gone)" :lol:
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
