What exactly is the cam lock tool needed for?
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
Is it essential for a motor that has VVT? I dont really understand why it is needed. If I set the cam gears to their marks, and mark the pulleys relative to the cams that would do it. What am I missing?
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
Its not needed. Use some whiteout to draw a line across the timing belt at each sprocket and the sprocket itself. Remove the old belt and transfer the marks onto the new belt. Double check by counting the teeth between the marks. Then just line up the new belt with the marks you just drew on your cam and crank sprockets. Piece of cake and it works just as well on both VVT and non VVT engines.
Ambitious but rubbish
boosted5cyl
Sounds good, thanks. One major omission on my part, sorry. :roll: What if the head is coming off?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Whne installing or setting the VVT units onto the cams you have to hold them steady and apply 90 ft/lbs of torque. You can get away without it for most other operations.
Retired
boosted5cyl
OK so what im interpeting is that i wont need to lock the cams when I am taking the head off, but its a really good idea when im putting it back together...Correct?
JDS60R
Post by JDS60R »
Unless you are taking the VVT unit off the cams you can get away without it. Its easier with it ,but not by too much.
Just leave your pulleys on the cams and if you have VVT mark the position of the pulley and the position of the cam after you release the VVT pressure.
If you don't have VVT I would try it without it and leave the pulleys on the cams -making sure to mark the tops of the cams.
Retired
Red-Arrow
Year and Model: 850 T5 1995
Been thanked: 2 times
Post by Red-Arrow »
If your removing the head then just cable tie the cams together and mark them as well for good measure.
Life would be enjoyable if it wasn't so painful to live.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Check out this excellent MVS tutorial. You won't have any problems.
Volvo 5-cylinder: How to Replace the Head Gasket
toddv850glt
Year and Model: '95 850 GLT
Post by toddv850glt »
U used a cam lock tool that I made myself kinda on that is avail from IPD. When doing a Timing belt change u will realize that the tool makes it so worth it
'95 Volvo 850 Glt N/A 5spd.
'96 Pontiac Grand Am
boosted5cyl
Thanks guys, I got the cams and the head off. Think ill make a cam lock tool like whats shown in the N/A guide linked here, I'm going to have to reset the VVT for sure from the looks of it....
