Rough Idle, Check Engine Light Illuminated
talbotpj
Year and Model: 2008 S40
Post by talbotpj »
Hi,
Drove my '98 S70 on a 400 mile trip yesterday and all went smoothly. After arriving at my destination, I grabbed some lunch then got back in the car 20 minutes later and was greeted by rough idling (between 500-1100 RPM) and a check engine light. The car still drives fine, but something is obviously wrong with it. I want to think it is just worn spark plugs, but I am not sure and have none of my tools with me to check. Any ideas? I have to drive another 400 miles Monday morning and would like to fix the problem beforehand.
1998 Volvo S70, 5 spd, 136k
Thanks,
Pat
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You have a CEL, read the code, please.
We can help but not blindly, you need to get that code read and post it
Sounds like you probably have a misfire code
talbotpj
Post by talbotpj »
Update: I finally read the codes and determined it is missing on ALL cylinders. Six codes in total, the 5 misfire codes and the "multiple misfires" code. I recently replaced the plugs, no help.
Why would all 5 cylinders suddenly start misfiring? Any ideas?
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
what plugs did you install???
Usually you just need to do a stage 0...
Plugs and wires.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Could be several reasons, but start by making sure your plugs are new and gapped correctly -.028"
Run the car with the hood up tonight and look for blue sparks around the area of the ignition coil (it is on top of the drivers side wheel)
'98 S70 T5
2016 Chevy Cruze Premier
talbotpj
Post by talbotpj »
The plugs were installed after the problems started and yes, they were gapped correctly.
The thing that confuses me is the fact that all 5 cylinders started misfiring at once. Would just one plug wire going bad cause the misfiring of all cylinders? Or would it be a component that affects all cylinders such as the distributor or coil.
The problems are only noticeable at idle, and more so when the engine is cold. It seems to rev up to 2000ish rpm's when cold and stay there for a few minutes.
eatcubensis
Year and Model: 850 t5r 95
Post by eatcubensis »
I am trying to resolve a similar situation. However, I feel the reason you have all of these codes is because you never cleared the codes to begin with. You need to clear all of the codes and then run your and see what codes come back up. Hope this helps.
jblackburn
'98 S70 T5
