2000 C70 Blower Motor
- Year and Model: Many Volvos
- Been thanked: 76 times
Welcome to MVS,
The flashing lights mean that the system is mad about something but without codes I can't tell you what that is. The real bummer is that you need to have the codes scanned at a shop that has a Volvo scan tool or its equivalent. A standard OBD-II scanner won't read climate unit codes.
If you can come up with the codes we can proceed from there.
- Has thanked: 312 times
- Been thanked: 818 times
Same fix - if you pull and report the codes, then we will know where to start.Jepc wrote: 08 Jul 2018, 05:29 Hi. Any luck fixing this issue? I have the same. Fan starts for 1 second then stops and lights flash. Help needed please. Cheers.
Is this for your 2006 C70?
A 2006 C70 is a very different car from a 2000 C70. You will need a VIDA setup to get the codes. It isn't hard to run VIDA on a Windows laptop but it requires some investment. Or take it to a shop that has VIDA, but getting the codes will likely cost you.
Your best bet is start a new thread over in the forum that includes your C70 viewforum.php?f=25
- 716 Views
Last post by Mojobaby27
- 1419 Views
Last post by SuperHerman
- 1301 Views
Last post by Fergy
- 46 Replies
- 12988 Views
Last post by 93Regina
- 632 Views
Last post by misha
