Torx screws, spark plugs... and turbo (1994 850 turbo)
So I'm trying to replace my spark plugs today, I have my torx bit all ready to go to take the spark plug cover off, and it turns out the bolts are so rusted up and stripped it it would be almost impossible to get them off. Not to mention three of the better conditioned bolts are blocked by the turbo and inaccessible to my wrench. How the heck am I supposed to work around this? advice?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Soak the bolts with lots of PB Blaster, then bear down HARD on your wrench/screwdriver and at sort of an angle, and you can probably get most of em loose. The ones around the turbo pipe can be got to with an extension easily, or you can remove the pipe altogether (it makes it much easier to slide the cover off).
Pick up some new bolts at your dealer if there's one close by. You can leave the cover off for the time being, but it's there to keep crap from getting under the spark plug boots that will fall down into the cylinders when you change plugs.
'98 S70 T5
2016 Chevy Cruze Premier
Thanks for the advice and the quick response, however I can see how the extender will work for one of the bolts obstructed by the pipe, but there are two that are partially covered by the pipe, inaccessible from above, I may be able to access them from an angle but they are pretty well covered up. How would I go about removing the turbo pipe? Sorry, I'm a noob mechanic.
- Year and Model: Many Volvos
- Been thanked: 76 times
I have had some difficulties getting the spark plug cover bolts out due to rusted out bolts and I just soak them in PB Blaste and then pound in the next largest size torx head bit into the old rusted out bolts. It isn't pretty but it works and you will need new bolts.
KRUZNBY
- Year and Model: '94 855T Wagon 117K
You can use a bolt extractor to get them out. It's like a bit that bites into the head as you turn it counter clockwise. Then replace the bolts with new ones.
'94 855T Wagon (120K)= Boost and a booster seat all in one.
Stage 0 in progress...
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
I used a wobble extension. Good luck.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
