So I went to Pep Boys to get an alignment and they said the left ball joint was bad. I just had a chance to get under the car and both boots are torn.
If I were to buy new ball joints and install them in approximately the same position I ought to be able to limp out to the mechanic a few miles down the road without too much trouble, right?
I looked at the boots for the lower control arm ball joints and those look OK. They wanted $64 for the one side plus another $64 for labor. I'm looking at buying both sides, Moog brand, for $30 each - sound OK?
Is there any other ball joint that I might be missing? Like I said, both steering rack ball joint boots are split but it looks like the control arm ball joints are OK as far as I can tell. Nothing is really loose or anything.
Replace steering ball joints?
thecheat
- Year and Model: 1996 850 Turbo Wagon
Now I'm looking at the quote again and it says "lf lower ball joint" so is that the control arm? That looked fine to me and i can't see it costing $65... I was expecting to pay $95 for it.
I need to replace the tie rod ends but i don't want to do that and then get there and have them tell me they won't do it because they meant the control arm... And then i have to pay $135 on top of it all.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
I just replaced a control arm on the left side of the 850R, and it cost $113 from Bap Geon. It was a European brand, and it wasn't hard. There is a write up here on how to do it. The end links were $53.00 each from Volvo dealer here. They were easy also. Good luck.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
thecheat
I was looking at $79 for a one-time front-wheel alignment to $100 for a 1 year/12,000 mile front-end alignment warranty. There was also a $10 "misc shop fees" line item which I wasn't happy about since that wasn't quoted when I asked about the cost of the job. I presume this is a way to make an extra few bucks for the store.
Didn't ask about a 4 wheel but I would say an extra $50 to $70 on top of that.
- Has thanked: 311 times
- Been thanked: 817 times
"lf lower ball joint" sure does sound like the control arm. Also usually a shop will not refer to the tie rod ends as a "ball joint" but as a tie rod or outer tie rod etc.
Why not just call the shop and ask "is that note about the control arm or the tie rod?"
Control arm is an easy job. You can get the part pretty cheap but beware they usually fail within a year. On control arms I HIGHLY recommend go with (1) genuine Volvo (about $105 at www.tascaparts.com) or (2) Lemforder or (3) TRW. Those are the only brands I know have proven themselves over the long term.
I had trouble with cheapie tie rod ends, the $15 ones the boots lasted only a year. I went with TRW and those have lasted 3 years now. Moog should be good.
I'd replace the tie rods ends with the torn boots anyway, replace the control arm, then bring it back in for alignment.
thecheat
I know everyone is going to hate me but I bought $50 control arms. I just need to stop chewing up tires in the short term and money is pretty tight right now. This is already costing $125 before I even get to the $100 alignment AND I had to buy a torque wrench but that's more of an investment because it's a tool.
I feel like such an ass for not dealing with this earlier... the front tires are WAY down on tread and the inside of the left tire is bad. I swapped them to the back and will likely replace them in a few months. I should have been more proactive because I KNEW the alignment was bad and now I get to buy two new tires in addition to the control arms and alignment.
The more I think about it, the more it seems they were referring to the ball joints on the control arms. I couldn't really see anything wrong with either side but I'm sure at 130k they should be replaced. Especially since the line item says "lower" and it would say "left tie rod" if that was the problem.
