My car is a '95 440 glt turbo auto, 101,000 miles found on ebay. Everything works and she's lovely, BUT......
She runs a rough idle (up and down from 500 to 1100rpm) hesitates on sudden acceleration, uses loads of fuel (currently 19.1 average!) The idle is better, in fact sometimes good, when cold and gets worse as she warms up, she runs/drives poorly when cold getting better when hot.
Took her for an MOT and got fails on two things, rear brake pipes corroded (not a problem, all done), and emissions (turning into a problem!) Now i'm guessing the idleing/running rubbish and emissions fail are the same problem.
The o2 reading was high, (1.24 test limit is 1.03), the hc reading was very low, as was the co2 (this was actually 0.01).
The low hc and co2 lead me to believe the cat is working properly. I've serviced her, new plugs and leads, fuel filter, air filter etc.
I've come up with a few possibles, but any other ideas or pointing me the right way will be appreciated.
Faulty lambda sensor. (but i thought the emissions readings don't suggest this but i'm not sure)
Leaking exhaust manifold/turbo/downpipe. (can't feel/see any)
Faulty MAF (cleaned with electrical contact cleaner, runs even worse with it unplugged)
Faulty ECU (i really hope not!)
Leaking injector/s
Thanks for any help in advance.
Rob
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
rough idle, high emissions, low mpg
- Year and Model: 440 GLT Turbo A '95
- Has thanked: 0
- Been thanked: 0
- Year and Model: 1998 S70 T5
- Been thanked: 6 times
Re: rough idle, high emissions, low mpg
Check first for any vacuum leaks, as they can definitely cause issues as well.
However, this sounds to me like a bad (front) O2 sensor (and that's not usually something I jump to), but this is what makes that stand out:
The O2 sensor doesn't give a reading until it warms up first.The idle is better, in fact sometimes good, when cold and gets worse as she warms up, she runs/drives poorly when cold getting better when hot.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 0
- Been thanked: 0
Thanks for your input. My Lambda sensor (o2 sensor) is of the pre heated type (fuse 13 on the board) but when the weather improves i'll check to see if it's got voltage through the fuse when cold.
The rough idle/poor running doesn't disappear completly at any point just improves under certain conditions.
Another thread states that my car being a turbo it won't have an obd unit, but i'm sure the thing is in there. Top of the suspension mount next to the battery. Think i'd best have a look!
- Has thanked: 0
- Been thanked: 0
I didn't have much luck at the garage, but a local scrapyard had a 440 turbo, so i had most of the fuel injection system.
The new ecu went in first, which cured the problem up. It now runs perfect.
Thanks for your help Bill,
- billofdurham
- Year and Model: 855, 1995
- Has thanked: 0
- Been thanked: 3 times
Good to know you have it sorted. Thank you for the update.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Rough and high idle
by Bird77 » Thu Dec 06, 2018 10:32 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 0 Replies
- 236 Views
Last post by Bird77
P0102 on 2001 2.9L S80 - Rough idle, cruise control doesn't engage, rough gear changes
by dav54123 » Sun Apr 07, 2019 11:51 am » in Volvo S80 Forum - First Generation 1999-2006 - 3 Replies
- 306 Views
Last post by DeadEric
Thu May 16, 2019 9:51 pm
01-XC Emissions - Low Evap Leak
by JoeMc » Thu Jan 31, 2019 9:35 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 5 Replies
- 236 Views
Last post by JoeMc
Fri Feb 08, 2019 6:48 am
1999 S80 T6 low/rough idle
by DonVanhugenstein » Wed Aug 31, 2016 8:18 pm » in Volvo S80 Forum - First Generation 1999-2006 - 2 Replies
- 784 Views
Last post by Rucho26
Mon Apr 01, 2019 6:20 pm
