Thanks for any words of wisdom anyone can give, Kent.
PVC and Rear Main Seal
remark90
- Year and Model: 1995 850 W 1999 V70
OK, so I replaced the PVC/Flame trap on my 95 850 about 5,000 mi. ago with lots of help from this forum. Last week started seeing oil on the driveway.
After some checking it seems to be coming from the the rear seal and once again I have oil vapor coming from the dipstick. Shit Hell! What should I be checking for to fix the PVC/Flame tram issue first, with a long shot it letting the rear seal do the job its supposed to do?
1995 850 N/A, Auto W/1999 V70 engine.
- Has thanked: 17 times
- Been thanked: 35 times
Hard to say but I did the PCV on my son's '94 850 non-turbo and still the gusher from the dipstick. I'm about convinced that it's in the oil pan- a hard right turn for the oil coming in from above, via the pcv breather box. I've heard the only real way to remedy this is to take the oil pan off and go from below. Any one concur, or have other opinions on this?
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
I would check the camshaft seals. The one behind the distributor is particularly difficult to detect, and looks like a rms leak. There is a how to on here somewhere.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
remark90
OK, I will check the cam seals, does anyone have an idea what I need to do to fix the PVC/Flame trap issue? Keep in mind its only 5000 mi old. BTW I purchased it from IPD.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
2 questions for you:
-Did you clean the two ports into the crankcase from the bottom of the oil separator box?
-Are the tubes on top of the box correctly routed? Some of the diagrams floating around out there are WRONG. I showed the correct routing in my repair write-up.
'98 S70 T5
2016 Chevy Cruze Premier
remark90
Just checking in, haven't driven the car so haven't had a chance to check the cam seals yet. I hopefully will have a chance towards the end of the month. Have a wonderful Holiday everyone.
- 11 Replies
- 5611 Views
Last post by wjhandy850
- 1157 Views
Last post by 93Regina
- 2441 Views
Last post by FCPEURO
- 1475 Views
Last post by Botbasher
- 773 Views
Last post by erikv11
