I been looking on E-bay at this one that I attached, it's not as good as the one I use to have at work but it looks okay.
https://www.amazon.com/Autel-AutoLink-A ... =hi&sr=8-2
[Note:Updated this link. -- Matt]
I've been looking at this model for a while cause it was more in my price range but now that I'm bringing in more flow I think I could spend more on something better. Any suggestions for something up to maybe a 100.00 or less if it's good, this OBDII is mostly for self but sometimes I do side jobs for people. Appreciate any opinions, thanks.
What OBDII Scanner Should I Get?
Volvo Diagnostic Code Lookup
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Reason: Updated link
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I have a Actron CP9410 PocketScan, just a basic code reader and nothing else fancy.
https://www.amazon.com/Actron-CP9125-Po ... ive&sr=1-4
The higher-end Actron models do some cool stuff for under $100.
'98 S70 T5
2016 Chevy Cruze Premier
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
That eBay one is only $30 through amazon.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Has thanked: 2856 times
- Been thanked: 1332 times
Copied and pasted from another post I wrote back in June, when it was $39.95. The link directly below has my Amazon affiliate ID embedded into it, so I'll get a % of that sale if you buy through them (plus a % of anything else on your order).
>>> Autel MaxiScan MS300 CAN OBD-II Scan Tool <<<
Disclosure: I get a small percentage of your purchase if you use that link to buy the scan tool.
I've had it since April, and I love it. It has a clear, simple readout I can see in daylight or no light because it's back-lit. It runs off the ODB port, so no batteries are required. It's small and light, and it works on my '97 850 as well as my 2004 V70 R. And yes, it turns off the Check Engine light in both cars. In other words, it clears codes.
It's got only two buttons so it's idiot proof.
Matty Moo
I bought this one last night, using the amazon link, for $126 shipped.
INNOVA 3130
https://www.amazon.com/INNOVA-3130c-Dia ... M86S6K602K
[Note:Updated this link with the successor Innova to Matty's scanner. -- Matt]
Overkill for most, but I need something that records, my Grand Cherokee has been acting goofy, but not throwing any lights. I need to see what's going on the second it does it. With this, I can drive around with it running.
Those Autel scanners are a steal. The Harbor Freight scanners are rebadged Autels, and sell for double.
INNOVA 3130
2000 s70 GLT
2014 Ram
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
I like this one for graphing stuff:
Only problem is right now you can't pull codes on my 95 with it for whatever reason. Supposedly the author is working on a fix. That's fine because I can pull them thru the OBD-I port. I haven't tried it with newer models of 850's, but I can pull codes on my wife's 98 Jetta.
Leto Atreides II
- Year and Model: 2005 XC70
I just bought that Autel MaxiScan MS300 off of Amazon. Unfortunately it doesn't seem to work at all. It always returns "LINK ERROR" and is unable to connect. I tried with the key in postion 0, I, and II all with the same result. Even tried with the car running. Maybe the MS300 just doesn't like my model year (2005 XC70)? Or is there some trick other than plugging it in and pushing the button?
JDS60R
- Been thanked: 3 times
I like the Rica PPC and the Actron CP9185. The actron is not as specific but is my carry along in the truck and does graphing so I can diagnose quite a bit while the customer or I drive.
Retired
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
No - It's a proprietary Volvo thing.
There's a tool by Draper that plugs into the OBD II port and resets it.
- 1701 Views
Last post by Volvo Tank
- 2872 Views
Last post by hu5ker555
- 2477 Views
Last post by jonesg
- 6317 Views
- 8619 Views
