igniton Problem?
my car shut down on me leaving a store, the engine turns over but wont start, check the ingition coils and spark plugs and all DO NOT WORK, i doubt all of the coils would go out at the same time allong with the spark plugs, what could be causing this ingition problem?
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
Is it possible that your timing belt broke?
jimgrames62
- Year and Model: 1999 s80
sounds like the throttle body problem? but i would take it to the dealer and get the diag? you can always use xemodex etm over a new stock one?
Next time it stalls, turn the key to II and see if you hear the fuel pump running. If not, I would check the fuel pump relay. Thats what it sounds like.
A crank sensor would usually give you starting trouble all the time, and the tachometer would bounce up and down.
oracleminded
- Year and Model: xc70 2001
Hi...did you ever resolve this...having same problem with 2001 xc70 t5. Very hard to star and tachometer jumps.
precopster
- Year and Model: Lots
- Been thanked: 128 times
See if there is a fuse related to engine management system. This could cut power to the coils or other engine management related functions.
I have only worked on 850s and 960s but this is what I would look at first.
Keep us posted.
Keep us posted.
- 1595 Views
- 12 Replies
- 3426 Views
Last post by Jaguar xjs
- 19 Replies
- 7471 Views
- 15 Replies
- 7858 Views
Last post by tango_1000
- 2586 Views
