My 1996 volvo had a brand new battery but it kept needing a jump to get started. I pulled the alternator, had it checked out and it was running @ 13.5-13.6v. I reinstalled the alternator, put a new serpentine belt on, jump started the car-let it run for fifteen minutes or so, took it for a ride and noticed the dash lights dimming slightly, the abs light flashing on and off a few times, my radiator light is still on too. I just put a new temperature coolant sensor in as well as a thermostat sensor when I installed a new thermostat. I've changed the heater core, the PCV system, put silicone vaccum hoses on (passed emissions)!
My car is now not starting or once I jump it, won't start again without jumping. I'm now thinking cam sensor, battery cables, ignition cable? Any help would be appreciated
1996 850 turbo wagon
jackief288
- Year and Model: 2004 XC70
- Has thanked: 2 times
- Year and Model: Many Volvos
- Been thanked: 76 times
You have an excessive parasitic drain on the system. You can normally track down what system is giving you trouble by putting an ammeter in series with a battery cable and then start pulling fuses, one at a time, until the current drops. Look things over for any aftermarket things that might have been installed as well like an old cell phone or an aftermarket alarm system.
The normal parasitic draw is less than 0.1 amp.
- phils94850
- Year and Model: 2009 s60 turbo
+1 on what lee said...
1996 Platinum Edition
VolvoTurbo850
- Year and Model: 1994 850 (T5)
Here is how you do it.
or this
or this
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
JRL
- Year and Model: Several
- Been thanked: 16 times
Have any of the battery cables been chenged?
They go bad and get to the point where they don't hold a charge
V850B5254T
- Year and Model: 2007 V70T aut
Hi All,
Recently my 97 850T automatic has developed a problem keeping the battery charged.
Battery is new (<6 month) and the generator is charging within acceptable limits.
I have tried to measure leakage (parasitic) current and removing fuses one by one and found no change en leakage.
At the start of this troubleshooting, the leakage was a steady 650mA but after fiddling around with fuses and connectors it fell to a mere 100mA as follows:
When connecting the am-meter and thus closing the circuit, the current starts at approx. 1Ampere, - after a couple of seconds it will decrease to 600mA, - then to 150mA and finally settle at 100mA.
Lee mentions that the normal parasitic current flowing from the battery should be less than 100mA :
Well, the leakage is 100mA with all fuses and relays removed, all connectors below the dashboard disconnected (including radio and other extras) and the motor and gearbox electronic pulled out of their sockets.
The current is measured on the wire leading from the battery to the fuse box, all other wires are still connected to the battery.
Does anybody know where this current flows?
The reason for my interest in a leakage current that apparently is within acceptable limits is that it fell from a unreasonable high (650mA) to the current level without any explanation and it might rise again without notice.
/oakey
Ozark Lee wrote:You have an excessive parasitic drain on the system. You can normally track down what system is giving you trouble by putting an ammeter in series with a battery cable and then start pulling fuses, one at a time, until the current drops. Look things over for any aftermarket things that might have been installed as well like an old cell phone or an aftermarket alarm system.
/oakey
Now:
Volvo V70T2 2007
Volvo S60T2 2005
Before:
Volvo 850T stc. 1996
Volvo 940T stc. 1998
Volvo 850 stc. 1994
Volvo 240 stc. 1988
Volvo 240 van. 1981
Ford Granada Van 1973
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
Volvo V70T2 2007
Volvo S60T2 2005
Before:
Volvo 850 stc. 1994
Volvo 240 stc. 1988
Volvo 240 van. 1981
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
The only thing left is the starter and the alternator after you pulled all of the fuses. I have seen alternator diodes short out and cause this problem but it is rare.
