850 parts for sale
Terens
Year and Model: 850R 1996
Post by Terens »
have a bunch of extra 850 parts available, figured i would let some of you have first grabs at them before they hit eBay...all from a turbo vehicle.
-T5 ECU's (a couple)
-Intercooler
-Turbo 15g
-Intake manifold
-Fuel rail
-Injectors
-PCV box
I might have other stuff I can't think of at the moment so ask if your interested.
-IPD Stage 1 ECU Tune, MBC and 18t Upgrade in the works!
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Gonna post about this, but if you have the manual climate control (MCC), I need the blower resister for the lower 1-3 speeds. Only my speed 4 works on the '94 850 (non-turbo). Thanks in advance.
Terens
Post by Terens »
have a picture of what it looks like? I could probably find one for you...
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Any chance you have a working brake switch up under the dash? (one where the shiftlock override doesn't need to be pushed every time)? If so, I'll gladly send you money for it!
'98 S70 T5
2016 Chevy Cruze Premier
begovic
Year and Model: 855 turbo 1994
Post by begovic »
Interested in 15g. Any shaft ply, will fit on 1994 850, price.....
Thank you.
Terens
Post by Terens »
begovic wrote:Interested in 15g. Any shaft ply, will fit on 1994 850, price.....
Thank you.
The turbo has minimal to almost no shaft play, need your zip code to calculate shipping. I can sell it for $150 + shipping to your zip code.
jablackburn - picture? There is an abundance of 850's at my local yard.
Terens
Post by Terens »
everything still for sale minus the inter-cooler. I also have more parts I didn't initially list so here they are...
-complete intake manifold with EGR, TPS sensor, throttle body
-Volvo water pump
-2x Turbo ECU's (072)
-Trans TCU from auto w/turbo
-Fuel pressure regulator (pre 96)
-Turbo Exhaust manifold with bolts
-Coil
-Alternator (Volvo)
-Side engine bracket
-Top side intercooler tube
-90 degree IC hose
-Exhaust heat shields (2x)
-Timing belt cover and top piece
I do have other parts available mostly from my swap, so please ask me if you don't see it!
I do not have the parts that you guys asked for, sorry. (above in thread)
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
pm sent terens
1996 Platinum Edition
Terens
Post by Terens »
one ECU sold, other is listed on eBay (with FREE SHIPPING) here is the link http://cgi.ebay.com/ebaymotors/94-95-Vo ... _500wt_975
I also have a top spark plug cover, and the fuel lines that run over the left top side of the engine and the black metal intercooler tube. I can also separate any of the items from the intake. I also have the 101-102 relay, a light control relay and a idler tensioner parts, I also have a set of rear deck speakers and a dash cluster from a turbo vehicle. I really need to get rid of this stuff so I can get my car to the dealership! Someone out there I'm sure needs some of this stuff. Also I would be willing to source or find parts if you need specifics.
SeaMike
Year and Model: 850, 1995
Post by SeaMike »
Hello,
Does the car have ABS w/track control on it?
If so what is the part number on the ABS Control Module Blue Sticker?
ABS-Volvo 850.jpg (92.61 KiB) Viewed 2802 times
