03 c70 random ignition problem
mittenxc70
- Year and Model: XCV70 2002
have random starting issues with c70. seem to have more trouble when the ambient temp is warmer. ignition was replaced about four years ago. problem is getting worse, sometimes takes four or five tries to fire. any ideas?
RaymanSean
- Year and Model: V70 XC, 2001
Vapor lock in the fuel line? Leaking check valve in the fuel line allowing fuel to drain back to the tank?
JRL
- Year and Model: Several
- Been thanked: 16 times
If it runs fine after it starts, it's FUEL not ignition
mittenxc70
sounds like that could be it. any ideas on troubleshooting the fuel supply system for a lock/check valve leak problem?
mittenxc70
ended up it was the chip in the key. new key, no problem.
- 5572 Views
Last post by SwissXC90
- 20 Replies
- 3261 Views
Last post by precopster
- 1698 Views
- 553 Views
Last post by Seaway
- 14 Replies
- 9172 Views
