99 s80 pcv cleaning?
jimgrames62
- Year and Model: 1999 s80
ok correct me if i'm wrong here but do you have to replace it??? can't you just clean and replace? or as far as that goes why isn't there a drain plug on it? really your just trying to avoid it getting full? couldn't a guy install his own drain plug with a self tapping screw at the bottom of the plastic box? i'd like to see pics of whats inside this thing? i've seen people retro fit there cars with the same type of setup with a plastic bottle. seems like a lot of work for such a simple device that should of had a drain plug to start with?
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
You bring up a very good point.
andrei3333
- Year and Model: 1999 S80 T6
Great questions, this oil trap should not have even been made....im think it collects oil but its not supposed to get full, it should recirculate it,
basically volvo over-engineered half this car and this is one of those things
1999 Volvo S80 T6 Bought @192KM...now @224KM and counting the high priced maintenance miles
537playing
jimgrames62
I think a self tapping screw should work just fine and simpler? The vapors that it traps is a liquid unless you don't drain it for 10 yrs!537playing wrote:How about a 1 inch plug like this one? http://webstore.petersenresources.com/l ... xpand.aspx
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
You are correct, in most cases it doesnt need to be replaced, but merely decrudded. A drain plug wont help with that however, all (well most) the oil drains out and back into the sump when the engine is stopped. Its the buildup of coke and sludge thats the problem.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jimgrames62
Heres a better view and explanation of what the pcv catch can is about.
http://www.redline9.net/thread-41.html
Most cars just redirect all the vapors right back in to the intake to be reburned. Much simpler but volvo tries to keep the motor cleaner by catching it in a container. If you have a way to drain it like every time you change your oil drain the pcv catch can then it won't build up and harden. If it does fill up in the catch can then this is how you get the blow by you see coming out of dip stick or oil cap.
jimgrames62
I got a self tapping screw from the hardware store and put it in and it worked perfectly. But to my surprise nothing drained out? Anyone ever take one of these pcv containers apart? Are there 2 chambers or what? Either mine is in good shape and functioning properly or maybe theres 2 chambers and i need to tap the other one?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
This is more or less what the inside of one looks like from a 5-cylinder engine. As said above, most of the oil drains out the lower port when the engine is shut off. But the sludge and crap builds up in the ports back to the engine block and eventually hardens into a clog that causes positive crankcase pressure.
'98 S70 T5
2016 Chevy Cruze Premier
537playing
I have a replacement PCV that I haven't installed, as of yet. Looking at the front of it, towards the bottom there is a there inch false wall. If you drilled in this range, you haven't hit a thing. As for the number of chambers, I can't tell but it is more than one.
- 1774 Views
Last post by ndphotonl
- 27 Replies
- 14842 Views
- 806 Views
Last post by volvobro
- 1173 Views
Last post by precopster
- 1585 Views
Last post by instarx
