Whining/whirring noise after shutting off engine (1996 850)
When I shut off the engine today on my 1996 850 wagon (base model, NOT turbo, 180,000 miles) I heard a whirring/whining noise from the engine compartment; it slowed down to a stop over about 5 seconds, with the noise getting quieter and lower in pitch. The best comparison I can think of is the sound of a turbine engine winding down to a stop. I've heard this noise from time to time over a couple of years, but it is not always present. Today it was unusually loud. I should mention that when I was driving, I thought I was noticing a new (different and hard to describe) noise when turning the steering. Could these things be related to the steering pump? I know this isn't much to go on, but I'm hoping that this is symptomatic of something that's well known in these parts. Thanks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Does your car have this big slinky tube that goes down over my battery out of the airbox here?
If so, that's the sound of your secondary air pump (for emissions) winding down. No need to worry about it, unless it's screaming or screeching while the car is running in the mornings.
'98 S70 T5
2016 Chevy Cruze Premier
VolvoTurbo850
- Year and Model: 1994 850 (T5)
there is a fan on the other side of that picture (passenger side) also in a black box that houses your ecu/ computer. It may run sometimes.
If not that then it would be your air idler pump where the throttle is (under a black cap). That would also give a whining sound but more of an air sound.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Did you checked your headlight viper motor?
Mine was stucked on once because the clips which are holding it's housing broke and the little axle with a gear was appart from the motor.I guess the contacts of the motor somehow touched themselves in the process.
You can always disconnect it by pulling off it's jack under the hood.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Maf sensor can NOT make any noise at all.There is no motor or anything like that in it...there's just a chip in it and that's all.
What CAN make noise is grey master relay for fuel system or iac(idle air control)valve.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2193 Views
Last post by theWIFES_S70
- 970 Views
Last post by vorbosh
- 1531 Views
Last post by IG-88A
- 213 Views
Last post by Blacklab467
- 1103 Views
Last post by cn90
