Ok I have read as many posts as I could find about clunking in front on the 2000 Volvo V70 XC.
The clunking is happening when I drive over small bumps and is quite loud and only on the front left wheel. I don't, however, notice any clicking or ticking noises when turning. The car does shake a little when turning, especially in reverse.
My first thought was struts or springs seats. I lifted the car and tried to move the springs and they seem pretty solid. If i really wrench on them they will move a little bit but not much. Not sure how to check the struts. Not even sure struts would cause a clunking noise.
I then grabbed the CV Joint and noticed there is quite a bit of play in the inner joint on that side as compared to the other side.
I have never heard of a CV joint making a clunking noise but it sure seems like this is the problem. Has anyone else had this same issue and found it to be the CV joint?
Thanks
Jesse
Clunk over small bumps on front left
jessekinsman
- Year and Model: 2000 V70XC R
- Year and Model: Many Volvos
- Been thanked: 76 times
Places to look:
Sway bar end links - check for a sloppy connection at its ball joint. and also check that it is securely torqued down to the strut and the sway bar. I have seen a couple that just had a loose nut.
Spring seat - try grabbing the large inverted castle washer at the top of the strut tower and try to twist it. It should move very little if it is good.
As was said,
Ball joints and control arm bushings - they should have no slop at all.
Tie rod ends, they too should have no slop.
As was said,
cudatime71
- Year and Model: 850 T5R 1995
Just got rid of my rattling front end today. Had a loud rattle over small bumps from the front passengers side. Lift the hood and stand on the side of the rattle next to your tire. Reach in with both hands and grab the top of the tire and try and pull it outwards while watching the top of the strut. As I pulled the top of my tire out, it moved about an inch and the top of the strut moved around. I replaced the upper strut mount bearing and the top coil spring seat. Presto, no more rattling and now the wheel is tight. The upper bearing was shot. I hope this helps.
1995 850 T5R Yellow
1993 850
1993 850
thecheat
- Year and Model: 1996 850 Turbo Wagon
If you can put your hands at 9 and 3 o'clock and attempt to turn the wheel left and right, that is probably the tie rod ends. If you can put your hands at 12 and 6 o'clock, that is likely ball joints.
I had to replace my ball joints and there was significant movement of the left wheel.
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
+1 on the sway bar links. they definately make noise when they are bad. I've had good luck with Meyle HD ones from FCP Groton.
good luck,
Andrew
good luck,
Andrew
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
claymore850
- Year and Model: 850 T5, 244, V70 2.4
Also check the sway bar rubbers, this unit is a one piece part, if you see cracked, loose or damaged you need to replace the entire unit. Its makes a clunk clunk ..metal noise at low speed, when the sway bar hits the support..
valvster
- Year and Model: 850 1996
Looks like some-one has come up with a repair kit for the sway bar....found THIS on a UK parts supply site....costs about $60claymore850 wrote:Also check the sway bar rubbers, this unit is a one piece part, if you see cracked, loose or damaged you need to replace the entire unit.
- lext
- Year and Model: 1994 854
- Has thanked: 1 time
I currently have something very similar, the only difference is that mine is on the passenger side (or maybe the same side, if "left" means left from standing in front of the car looking in).
One thing I'm not sure about though, is that the clunking only happens when driving over bumps. There's no clunking when I bounce (push down and release) the front end of the car. Does that mean it's not the struts bearing? I imagine if it's that then bouncing up and down should produce the same sound.
I've already replaced the sway bar links but that didn't help. Next I'm planning to replace the tie rod ends but am having trouble taking it apart. If that still fails I'm thinking of replacing the struts .. unless someone says that "if bouncing car has no clunking then strut is fine".
94 850 non-turbo
2011 S40 T5
2011 S40 T5
- 11 Replies
- 6456 Views
Last post by lostmyVcardXC
- 1633 Views
Last post by dmack87
- 901 Views
Last post by r_ziots70
- 1214 Views
- 1580 Views
Last post by E Showell
