v40 1.9td blowing smoke Topic is solved
mrslash
help i just brought a 1998 v40 1.9td and its kicking out clouds of smoke is it a major problem as there is loads of power and it runs fine
alfonzobonzo
- Year and Model:
Piston rings?
head gasket?
Turbo oil seals?
but deffinately burning oil from some where, check your level frequently.
possibly fail its next mot, depends how bad it is, could be expensive to fix if your not doing it yourself, does it allways blow smoke or is it just under heavy accelleration? would narrow it down to turbo problem.
head gasket?
Turbo oil seals?
480 L 1994 2.0 i Metalic Black K&N Panel
V40 W 2000 1.9 T4 Metalic Black
Guest
its seems to be worse when you first start it and under idle conditions give it a good hard acceleration and it doesnt seem to be as badalfonzobonzo wrote:Piston rings?
head gasket?
Turbo oil seals?
alfonzobonzo
- Year and Model:
sound perhaps like there may be a small amount of oil leaking into the cylinders, perhaps the first sign of head gasket going??
how many mile has it done? & how handy are you with a spanner? & how much spare time have you.
if the answer to these questions is not very, then i suggest either leaving it till it gets too bad, or get a deisle specialist to look at it , (not a volvo dealership)
Guest
i have looked again today and there is oil in the water header tank so i think it is deffo head gasketalfonzobonzo wrote:sound perhaps like there may be a small amount of oil leaking into the cylinders, perhaps the first sign of head gasket going??
alfonzobonzo
- Year and Model:
Bingo.
wont cost much to do yourself, if youve got the time & inclination,
dunno how much a garrage would charge
let us know how you get on & Good luck .
Guest
many many thanks going price up parts this weekend to a view of doing it next weekalfonzobonzo wrote:Bingo.
wont cost much to do yourself, if youve got the time & inclination,![]()
dunno how much a garrage would charge![]()
alfonzobonzo
- Year and Model:
any probs just post here, i'll keep an eye out, and help/advise if i can,
done it loads of times now.
i have a 2000 S40 and every once in a while i see smoke in the rearview mirror--not necessarily when accelerating heavily, either. I get over 29 miles per gallon on the highway and it runs fine, so i'm just ignoring it to tell you the truth.
Guest
I had on my V40 TD -97 heavy black smoke when accelerating.
It was also hard to cold start the engine.
I was expecting the worst... Bad pistrons, rings etc...
It was just that the walves needed to be adjusted. Two of the intake walves did not close at all...
- 3397 Views
Last post by jonesg
- 1748 Views
Last post by difflock54
- 2034 Views
Last post by 90 Beater
- 2765 Views
Last post by IVIUSTANG
- 1986 Views
Last post by jimmy57
