Hi,
About to buy a 04' XC70 (100K mi.). The back rotors look fine but the front look like they need replacing (grooved and thin). My question is, is it bad to replace only the front with different rotors (Zimmerman) and possibly pads (Akebono) compared to the stock rotors and pads at the back?
I think I may have to replace the front pads too. They are brand new but looks like the grooves in the worn rotors will mess them up for the new rotors, yes?
I am a noob so go easy on me.
Thanks.
Replacing only front rotors...
precopster
- Year and Model: Lots
- Been thanked: 128 times
Welcome to the forum. Front brakes have different wear rates than rear brakes (around 75% BIAS TO THE FRONT) so it's perfectly OK to have one axle changed at a time. All workshops operate the same way. Yes, definitely change the pads with new ones if the rotors are to be replaced.
The new rotors will last longer with new pads and the rotors and pads' mating surfaces will match. If the old rotors are thin, scored, glazed and grooved as you mentioned, the pads will probably have been overheated.
If you are doing it yourself make sure you remove all anti-rust coating from the disc with a non-oil based spirit. It is very important to bed in new pads as per the manufacturer's recommendations. This may involve 5-6 hard stops from 35mph without coming to a full stop.
Not too sure about Akebono pads, they may be a ceramic pad, can anyone chime in here?
Thank you, very helpful.
Yes, Akebono are ceramic and the forum has some glowing reviews about them (as well as Zimmerman rotors). I did see a youtube video that also outlined the importance of using brake cleaner on the rotors as well as the grease supplied.
confused_al
- Year and Model: 1996 TLA wagon
I am using Akebono Euro for all my Volovs' now, they are great, little dust and good braking power. Rotor wise, I switched from Zimmerman to ATE PremiumOne, not only because ATE is only half as much as Zimmer, (use Matt's amazon.com link you will find it), but also Zimmer is so easy get rusted all over. Moreover, I buy into the theory that hard pads are better to pair with softer rotors or vice versa. Ceramic pads are harder than semi metallic pad such as Volvo oems.
The bed-in procedure is a bit differ for ceramic pads...
http://www.tirerack.com/brakes/tech/tec ... ?techid=85
BTW, here is a couple of very good DIY write-ups:
http://www.freewebs.com/dacvolvo/brakediscsandpads.htm
http://volvospeed.com/850fbrake1.php
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
confused_al
If you use genuine Volvo pads and rotor that is usually the life span. Ceramic pads might wear rotor a bit faster and the pads themself last a bit longer.sacksyboy wrote:Are you experiencing 2x pads to every 1x rotor replacement?
About the average in east coast, less than Ohio where I use to live.sacksyboy wrote:Do they salt the roads where you are?
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Thanks.
BTW - I hate dealers, scum of the earth. Secured the '04 XC70, ready for pickup next morning. Dealer sells at higher price to woman that walks in as they open. He really lived up to the poor reputation they have.
JRL
- Year and Model: Several
- Been thanked: 16 times
If you do use Zimmermans, they make a COATED rotor that's about $5 more than the standard rotors and it's not as prone to rusting and discoloring.
I just bought a pair for a car I'm working on, about $35 per rotor, not bad
Do NOT buy the slotted rotors for the street, they don't get hot enough and make a lot of noise as they get a bit older
precopster
JRL you may have missed the thread purpose: sacksyboy started the thread because he was about to buy a '04 XC 70 which he wanted brake advice about.
The dealer sold the car to someone else. Sorry to hear it sacksysboy.
Next time insist on leaving a deposit, they can't do a double take on you or at least it's less likely!!
- 2275 Views
Last post by fishingdad101
- 1172 Views
- 15 Replies
- 8144 Views
Last post by walczyk
- 1956 Views
Last post by FCPEURO
- 1685 Views
