Camshaft Position Sensor Terminal Wire Colors
breid95
Year and Model: 960, 1996
Post by breid95 »
I sure hope a mechanic is out there reading over new postings for 1996 960 model help. Fault code is CMP sensor. My issue is cant test the terminal connectors because some mechanic or owner removed wires from sensor connector and spliced the wires together. Car is hard to start and bucks at interstate speeds. My issue right now is testing the circuit. need 3 wire colors
One is ground, one is "signal return should test at 5 volts, 3rd wire should test at battery voltage. and I sure don't want to mess up I am using Chilton repair manual as mentioned some took connector off and spliced wires directly behind the engine
thank you so much for any help
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Attached is wiring diagram for the fuel/ignition system. The camshaft position sensor is 7/21.
1996 960 CMP sensor wiring.pdf
(277.33 KiB) Downloaded 1209 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
