850 turbo wagon no start
I'm trouble shooting a no start condition. Steps so far.... Fuel pump is confirmed running, no spark at coil hot wire to ground, cam position sensor showing voltage out (5-0 and back). I'm currently looking for the crank position sensor. I found the vehicle speed sensor (same as crank sensor?) and it reads .995 ohms across it. Is the crank position sensor on the top side of the belhousing? Could it be simply the coil? Help please!!
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
Thankyou for the info on the cam sensor. I back probed the middle wire, turned engine over, and got a constant 0 to 5 volts out. Can the cam sensor still be bad? I'm also showing a engine speed output on my live data program on the laptop. I've heard the crank position sensor can also kill spark to the engine. Any thoughts on the crank sensor? Where the hang is it??
- gmh
http://www.eeuroparts.com/Main/PartsResults.aspx
Then click the diagram on the left, it is part #11 on the page.
http://data.eeuroparts.com/Images/diagr ... 91d0b4.gif
Sorry, I don't know anything about the electrical diagnostics.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1969 145S (1987-91)
1973 145E (1989-90)
machomateo88
- Year and Model: 1994 850 Turbo
Anything new on this topic? My 850 Turbo has the same exact condition. No start, just cranks.
stutteringp0et
- Year and Model: 855 Turbo, 1995
Do you smell a lot of gas? I mean, really smell a lot? I did.
I had this issue, and the dealer fixed it by replacing what they described as a "freeze plug" in the intake manifold. I don't think they ever told me what it was actually called.
Apparently it can just pop out. I never saw it myself, but next time I get crank but no start, you can bet I'll be examining the intake manifold with a magnifying glass in order to save myself a $700 repair bill.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Looks like it's at the end of the intake manifold where the vacuum hose connects. Freeze plugs are there as a precaution to prevent parts of the car from expanding and cracking the engine block/manifold (in your case).
freeze plug.pdf- (77.05 KiB) Downloaded 481 times
'98 S70 T5
2016 Chevy Cruze Premier
- 1147 Views
Last post by Jeffkindelspire
- 12 Replies
- 1751 Views
Last post by erikv11
- 1312 Views
Last post by maverill
- 1773 Views
Last post by jmorman
- 938 Views
Last post by manovlov
