1998 headlight wiper motor removal
mcg122
Year and Model: 2001 V70 T-5
Has thanked: 5 times
Post by mcg122 »
I've been trying to remove the left side headlight wiper motor from a 98 V70 parts car I just picked up. It seems as if I need to remove the radiator, or at least unbolt the actual crossmember that the radiator is attached to, in order to be able to slide the motor out from between the radiator and the crossmember. I'm going to be removing the radiator & intercooler before I junk the car, but I'm not so sure I want to bother with replacing the motor on my 99 wagon if it means I have to disassemble half the front end to do it! Thanks in advance for your help. :D
OK, I see many views, but no resolution..I went to my local Volvo dealer & spoke to the shop foreman, he said it should just "wriggle out" without having to remove the radiator or the crossmember, I'll have another look & update.
Either way, I think I'm just going to unplug the wiper motor on my driver & leave it!!
MCG122
2007 XC70 (Mine)
2001 V70 T5 (Son's)
2001 S60 T5M
2008 S60 AWD work in progress... :?
1973 1800ES, 4 spd w/od, of course! 157k, or so...
Eight or ten 98-2000 P80s, a few 240s, and more 122s than I can remember!!
