Cruise Control on 1994 940 Turbo Needs Work -- But What?
This topic is in the MVS Volvo Repair Database » New Volvo S60 R-Design: Fast
rob2volvos
Year and Model: 1992 740 / 1994 940
Post by rob2volvos »
Over the past few months, the cruise control on my 1994 940 has gradually malfunctioned to the point now where it barely works. I get up to speed, press the cruise control, the speed might drop to 5-10 mph below the target speed and I can feel it pulling but it's weak and fades. So it's as though the vacuum isn't being held properly (and I suspect the colder weather has made the problem worse).
Last weekend, I inspected the associated vacuum tubing, the pump mounted on the driver's side strut housing and the rubber bellows-thingie hooked to the accelerator cable and it all looks fine -- nothing obviously wrong. Can anyone comment on this / suggest a good testing procedure to troubleshoot the issue?
Much Obliged,
Rob
Kirby J
Year and Model: 99 v70, 93 940
Post by Kirby J »
Mine does the same thing, and I have also found no vacuum leaks. I have found that after the car is fully warmed up, the cruise works just fine. I suspect old hardened lines that only leak when they are below 40F. Or maybe it is a lubrication issue-very cold grease does not work as well as warm grease.
Kirby J
93 945 391k and counting
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You can connect the cruise control module to the OBD unit and pull diagnostic codes.
The attached shows how:
940 Cruise Control Diagnostics.pdf
(3.66 MiB) Downloaded 258 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
rob2volvos
Thank you both for very helpful posts.
Hey, Bill -- You have quite a stack of useful PDFs in your back pocket -- Good Man!
Rob
