constant open loop
landyacht33
Post by landyacht33 »
96 volvo 850 turbo
I have been posting for the past couple of weeks on a rough idle with no codes and cant figure out the problem. today i hooked my car up to my buddies computer and i stated the car stays in open loop and it is running at 20.9 RICH! I am assuming o2 sensor but am open to ideas most certainly
thanks
Adam T
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
If it is running in open loop mode there should be a code to tell you what it is mad about if the ECU is working properly.
landyacht33
i suppose the ecu isnt working properly then. GREAT
i have a non turbo ecu but that does me no good right?
there is no codes given, i check everytime i put it in park
landyacht33
i have a couple of extra o2 sensors in my donor car. you think i should try those to see if it fixes the problem? the donor is a non turbo but i dont think it matters
landyacht33
alright i robbed the front o2 from my non turbo donor car and it fixed the problem. apparently n/a and turbo cars use the same o2 sensors so there you go.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Yes,o2 sensors for turbo & non-turbo cars are the same.Maf sensors are the same too except of early 850's made from '92-'94.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
