massive oil leak
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
pip68nz
Year and Model: 2000 s80 t6
massive oil leak
Post by pip68nz »
my 2000 s80 t6 has a massive oil leak it looked like it was coming from behind water thermostat ,pulled off thermo cover and find that oil must be coming from above maybe from cam.is there any advice on how to fix problem please.or how to replace cam seal.
cheers
JDS60R
Been thanked: 3 times
Post by JDS60R »
Remove the spark plug cover and determine if it is the oil cap gasket or the cam seal.
The oil cap gasket needs replacement occasionally but if there is pressure behind it then you have a oil trap issue. Take a rubber glove and put it where the oil cap was. Run the car and see if the glove gets sucked in or blown up. (if glove is filling with air then you must replace oil trap)
Let us know what you found.
I will post procedures for both.
Retired
JDS60R
Post by JDS60R »
Here is the procedures for the cam seal and VVT
I couldn't find the flame trap/oil trap but its posted here - search flame trap if you need it. Its a black box and some hoses usually mounted under the intake manifold
2000 S80 cam seal.pdf
(318.33 KiB) Downloaded 491 times
2000 S80 VVT.pdf
(318.17 KiB) Downloaded 595 times
2000 S80 intake removal to get to flame trap.pdf
(426.27 KiB) Downloaded 227 times
Retired
pip68nz
Post by pip68nz »
thanks very much will try this.
cheers
