A/C Evacuation & Recharge
Capt RJ
Post by Capt RJ »
I'm looking for the high side fitting on my '96 850 Turbo but can't find it. Is there one or do you pull a vacuum and recharge using only the low side?
Also, does anyone know how much 134A is required for a full charge?
Thanks!
Bob Martin
1996 850 Platinum Edition
1998 V70 T5
Jot
Year and Model: C30 2010
Post by Jot »
It is all done with thw fitting that has nm on the cover. located near the passenger headlight
ccb222
Post by ccb222 »
My '95 850 Turbo Wagon takes 1.65 lbs R134a if that helps.
Jaxx
Post by Jaxx »
try to find someone who does HVAC and they should have gauges for you, that's what my dad does and he has some "yellow jacket" gauges that can tell you pressure, etc etc, it's a nice tool if you frequently recharge your AC, but they are fairly expensive. http://www.yellowjacket.com/wn2.cfm?cat=1 it's on that page.
HTH
jaxx
1995 850 T5
...K&N airfilter...upped boost...Joy Life Alarm...
143,000 and some.
jthompson
Post by jthompson »
I have found my evaporator to be the cause of a leak in my a/c system via eletronic sniffer. Is this common and is replacement done through the cowl or dash removal? Any est. for evap cost? Thanks!
Jot
Post by Jot »
A Dealer will take your wallet and right arm. I had a Volvo mechanic change 2 (two) on a saturday morning.Three hours for each.The entire dash needs to be removed.
