S60 Start Issue
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
This sounds like an antenna ring issue to read the chip in your key. If it doesn't detect the chip, it will shut the motor down to prevent the car from being stolen.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
I can't find the part from the online vendor sites I have tried; but a dealer should be able to order the part for you - it is the little ring around the ignition slot, and can easily be replaced by yourself with just a Torx screwdriver.
'98 S70 T5
jblackburn
If the car is starting and running, the fuel pump is ok. It's above the fuel tank, and a pain in the rear to change.
'98 S70 T5
jblackburn
You can test the fuel pressure at the end of the fuel rail - on older models of the 5-cylinder, there is a schraeder valve at the end of the fuel rail on the drivers side of the engine. As I recall, the numbers on an AWD engine are slightly higher - mid-50 PSI without the engine running; high 40's at idle. I can look up the exact specs for you tomorrow when I have my other computer.
If the engine kept cranking and then shutting down quickly, it may have flooded itself. Pull out the plugs and see if they are wet with gasoline, and check to make sure that they are firing when the engine is cranked. Allowing the cylinders to air out, and a tiny bit of oil in each may get the engine to start again - but if it keeps running and then shutting down again, there's another, likely alarm-system related problem.
'98 S70 T5
- 4445 Views
- 1221 Views
- 56 Replies
- 10808 Views
Last post by nucci480
- 238 Views
- 1028 Views
Last post by darylrobert
