VOLVO 440.TURBO 1988. LER GAS
kako da resim ler gas na mom autu, kada ga upalim stalno drzi na 1200-1500 obrtaja , ne znam da li je upitanju protokomer ili nesto drugo. cak mi ne radi ni kilometar sat kao ni na bord racunarau cela leva strana
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Unfortunately, I can't read Serbian/Croatian and have had to rely on a Google translation. This has still left me with some words that I do not understand. Is it possible for you to translate your question into English?
Dobrodošli na Matejev Volvo stranice.
Nažalost, ja ne mogu čitati srpski / hrvatski i morali oslanjati na Google prijevod. To još uvijek mi je s lijeve strane neke riječi koje ja ne razumijem. Je li moguće za vas da prevesti vaše pitanje na engleski?
This is what came from the translation : (To je ono što dolazi od prijevoda:)
Bill.how to solve idle on my car, when you turn it on permanent hold on the 1200-1500 rpm, I do not know whether upitanju rotameters or something else. even we do not work either kilometers an hour, or on bord racunarau whole left side
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Ok my friends...here's translation:
VOLVO 440 TURBO 1988.IDLE SPEED
How can i solve a problem with idle speed on my car?When i start it rpm's are all the time at 1200-1500rpm,i don't know if there is a problem with Maf sensor or is there something else wrong?My odometer also don't work and left side of trip computer.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- billofdurham
Thank you, Misha. Now I've got to do some work.
milence, is the idle speed problem only on first start up and decreases as the engine warms? If it stays at the high revs all of the time there is an idle speed adjuster which may have been turned accidentally. There is also an auxiliary air valve under the throttle position switch which controls the idle speed during warm up.
Bill.
Bill.
Previously:
Previously:
- misha
No problem!billofdurham wrote:Thank you, Misha. Now I've got to do some work.![]()
Bill.
Prevod na Srpskom:
Milence,da li imas problem sa ler gasom samo posle prvog paljenja i da li se obrtaji smanjuju kad se motor zagreje?Ukoliko ostaju visoko svo vreme postoji jedan deo koji steluje ler gas i koji je mozda slucajno okrenut(rastelovan).Takodje postoji i jedan sekundarni ventil za vazduh ispod klapne za gas(prekidaca za gas) koji kontrolise ler gas dok se motor zagreva.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
For all: Milence are you able to read in bulgarian? If so, just tell me to give you a link in Bulgarian forum with a solutions of same problems.
For Milence (na balgarski): Milence moshesh li da chetesh na balgarski (kirilica)? Ako moshesh samo mi kaji da ti dam linkove v balgarskia forum s reshenia na tvoia problem.
!!! SPAM !!!
Why don't make a group conversation trough skype. Just Idea - it will be faster and easyer to comunicate...
For Milence na balgarski:
Zashto ne naprawite edin grupov razgovor po skype. Prosto idea - taka po-lesno i po-barzo ke se razberete...
!!! SPAM !!!
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
hvala ti puno prijatelju, daj mi i forum na bugarskom pa cu ga ja prevesti, i hteo sam druze da te pitam gde se nalazi ta klapna - prekidac za gas ako mozes da mi objasnis, hvala ti unapred puno i izvini sto me nije bilo dugo, pozdrav za tebe i tvoju porodicu
jeste druze non stop drzi n a1200-1500 obrtaja i to stalno. ide on super , dobra mu je vuca samo me to muci cak i dok je ladan ima nepravilan rad ler gasa dok se ne zagreje pa onda drzi na 1200-1500
yuckuJackD
For all:
I got just 80% but the bad think is that the other 20% seems to be important to get the whole meaning. Here they are some topics in bulgarian about the rpm (not just hight, but globaly problems with rpm).
http://volvoclub-bg.com/forum/viewtopic.php?f=4&t=6562
http://volvoclub-bg.com/forum/viewtopic.php?f=4&t=10416
http://volvoclub-bg.com/forum/viewtopic.php?f=4&t=13632
And this is link for forum named like this one "Volvo 4XX and so" : http://volvoclub-bg.com/forum/viewforum.php?f=4
On Bulgarian rpm is wrote: "обороти"
GOOD LUCK
За Миленце:
Ja razbrah samo 80% no shto e losho e ke drugo 20% e wajno i izpuskam znachenieto. Tuk sa nqkolko linka kym temi na balgarski za oboroti (ne samo wisoki a kato cqlo problemi s tqh). Opitwam se da zwuchi po srybsko, ne se smej
To maj nito na balgarski nito na srabski ama...
A towa e link kym foruma s ime "4XX i prilejashti": http://volvoclub-bg.com/forum/viewforum.php?f=4
Na balgarski se pishe "обороти"
УСПЕХ
GOOD LUCK
За Миленце:
УСПЕХ
- 15738 Views
Last post by Medusalith
- 15894 Views
Last post by pastoralia
- 1187 Views
Last post by lummert
- 601 Views
Last post by mrt740
- 23 Replies
- 7610 Views
Last post by MrAl
