IPD sale Volvo Parts
Did you know? 🤔
VOLVO 440.TURBO 1988. LER GAS
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
milence
Year and Model: volvo 440.turbo 1988
Has thanked: 0
Been thanked: 0
milence
Post by milence » Wed Jan 19, 2011 3:05 pm
kako da resim ler gas na mom autu, kada ga upalim stalno drzi na 1200-1500 obrtaja , ne znam da li je upitanju protokomer ili nesto drugo. cak mi ne radi ni kilometar sat kao ni na bord racunarau cela leva strana
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
x
Post by billofdurham » Thu Jan 20, 2011 11:48 am
Unfortunately, I can't read Serbian/Croatian and have had to rely on a Google translation. This has still left me with some words that I do not understand. Is it possible for you to translate your question into English?
Dobrodošli na Matejev Volvo stranice.
Nažalost, ja ne mogu čitati srpski / hrvatski i morali oslanjati na Google prijevod. To još uvijek mi je s lijeve strane neke riječi koje ja ne razumijem. Je li moguće za vas da prevesti vaše pitanje na engleski?
This is what came from the translation : (To je ono što dolazi od prijevoda:)
how to solve idle on my car, when you turn it on permanent hold on the 1200-1500 rpm, I do not know whether upitanju rotameters or something else. even we do not work either kilometers an hour, or on bord racunarau whole left side
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
misha
Has thanked: 26 times
Been thanked: 87 times
Serbia
misha
Re: VOLVO 440.TURBO 1988. LER GAS
Post by misha » Tue Jan 25, 2011 9:37 am
Ok my friends...here's translation:
VOLVO 440 TURBO 1988.IDLE SPEED
How can i solve a problem with idle speed on my car?When i start it rpm's are all the time at 1200-1500rpm,i don't know if there is a problem with Maf sensor or is there something else wrong?My odometer also don't work and left side of trip computer.
'97 850 2.5 20v /fully equipped/ Motronic 4.4 / polar white wagon
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Wed Jan 26, 2011 11:52 am
Thank you, Misha. Now I've got to do some work. :roll:
milence, is the idle speed problem only on first start up and decreases as the engine warms? If it stays at the high revs all of the time there is an idle speed adjuster which may have been turned accidentally. There is also an auxiliary air valve under the throttle position switch which controls the idle speed during warm up.
Bill.
Previously:
misha
Serbia
misha
Post by misha » Wed Jan 26, 2011 1:20 pm
billofdurham wrote:Thank you, Misha. Now I've got to do some work. :roll:
Bill.
No problem! :wink:
Prevod na Srpskom:
Milence,da li imas problem sa ler gasom samo posle prvog paljenja i da li se obrtaji smanjuju kad se motor zagreje?Ukoliko ostaju visoko svo vreme postoji jedan deo koji steluje ler gas i koji je mozda slucajno okrenut(rastelovan).Takodje postoji i jedan sekundarni ventil za vazduh ispod klapne za gas(prekidaca za gas) koji kontrolise ler gas dok se motor zagreva.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
yuckuJackD
Year and Model: XC70; S80; S40
Has thanked: 0
Bulgaria
yuckuJackD
Post by yuckuJackD » Thu Jan 27, 2011 7:24 am
For all: Milence are you able to read in bulgarian? If so, just tell me to give you a link in Bulgarian forum with a solutions of same problems.
For Milence (na balgarski): Milence moshesh li da chetesh na balgarski (kirilica)? Ako moshesh samo mi kaji da ti dam linkove v balgarskia forum s reshenia na tvoia problem.
!!! SPAM !!!
Why don't make a group conversation trough skype. Just Idea - it will be faster and easyer to comunicate...
For Milence na balgarski:
Zashto ne naprawite edin grupov razgovor po skype. Prosto idea - taka po-lesno i po-barzo ke se razberete...
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
milence
Has thanked: 0
Been thanked: 0
milence
Post by milence » Thu Feb 17, 2011 1:53 pm
hvala ti puno prijatelju, daj mi i forum na bugarskom pa cu ga ja prevesti, i hteo sam druze da te pitam gde se nalazi ta klapna - prekidac za gas ako mozes da mi objasnis, hvala ti unapred puno i izvini sto me nije bilo dugo, pozdrav za tebe i tvoju porodicu
milence
Has thanked: 0
Been thanked: 0
milence
Post by milence » Thu Feb 17, 2011 2:08 pm
jeste druze non stop drzi n a1200-1500 obrtaja i to stalno. ide on super , dobra mu je vuca samo me to muci cak i dok je ladan ima nepravilan rad ler gasa dok se ne zagreje pa onda drzi na 1200-1500
milence
Has thanked: 0
Been thanked: 0
milence
Post by milence » Thu Feb 17, 2011 2:14 pm
и заборави да те питам за тај део које штелује лер гас и где се он налази. ти објасни колико мозеш и ја сам ти захвалан
yuckuJackD
Has thanked: 0
Bulgaria
yuckuJackD
Post by yuckuJackD » Tue Feb 22, 2011 3:53 pm
For all:
I got just 80% but the bad think is that the other 20% seems to be important to get the whole meaning. Here they are some topics in bulgarian about the rpm (not just hight, but globaly problems with rpm).
http://volvoclub-bg.com/forum/viewtopic.php?f=4&t=6562
http://volvoclub-bg.com/forum/viewtopic.php?f=4&t=10416
http://volvoclub-bg.com/forum/viewtopic.php?f=4&t=13632
And this is link for forum named like this one "Volvo 4XX and so" : http://volvoclub-bg.com/forum/viewforum.php?f=4
On Bulgarian rpm is wrote: "обороти"
GOOD LUCK
За Миленце:
Ja razbrah samo 80% no shto e losho e ke drugo 20% e wajno i izpuskam znachenieto. Tuk sa nqkolko linka kym temi na balgarski za oboroti (ne samo wisoki a kato cqlo problemi s tqh). Opitwam se da zwuchi po srybsko, ne se smej :) To maj nito na balgarski nito na srabski ama...
A towa e link kym foruma s ime "4XX i prilejashti": http://volvoclub-bg.com/forum/viewforum.php?f=4
Na balgarski se pishe "обороти"
УСПЕХ
