2001 V70.
MAF has been cleaned, new plugs, and ETM were tested and runs within limits. Throttle body was cleaned( well wiped by a tec. they say). We had the car checked and of course nothing found.
Here's what's going on. Warm the car up. While car is in N, you rev. it to 3000 RPM. As it goes below 1000 rpm to say 800 all of a sudden we get a rough idle, goes up 1000 Rpm and then feels OK till you do the same thing again. This doesn't occur all the time. When you rev the engine and it gets to this "coughing" point the car's lighting dims and then brightens again.
While driving as you slow down the rpm drops to just below 1000 to 800 rpm you get a little shake then it goes away. There is no wild swing in RPM with a bad ETM. We do notice that there seems to be a louder exhaust noise coming from the catalitac(sp) converter section.
Any thoughts. I don't have a code reader.
Rough Idle when engine goes under 1000 RPM
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Wait, when the engine drops to 800 and it coughs, the lights dim?! How significantly do they dim? I'm thinking an intermittent charge controller in the alternator could cause that. Everything on these cars rely on a good source of electricity, so if something like the alternator's putting out bad current (or there's a bad ground causing the alternator to be unable to charge the battery/electrical system), that could definitely cause these symptoms. Do you have a volt-ohm meter?sahdct wrote:This doesn't occur all the time. When you rev the engine and it gets to this "coughing" point the car's lighting dims and then brightens again.
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- 3769 Views
- 73 Replies
- 30354 Views
Last post by quietcoolone
- 3035 Views
- 504 Views
Last post by 850T5Ritalia
- 2208 Views
Last post by Reys
