v70 2001 temperature sensor
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
If you start engine and the cooling fan comes on immediately on high speed then there is something wrong with wiring between sensor and ECM. IF the cooling fan is operating normally and the gauge going full gauge is the only symptom then it would seem the DIM is going wonky on you.
Brentscrazyptwo
- Year and Model: 2004 S60 2.5T
- Has thanked: 11 times
Jimmy57, what is the best approach to checking that purple wire to the radiator fan or the temp sending unit? I have a new radiator and it ran on high as soon as I turned the car on. Now it doesn't run at all. Engine temp is normal but the transmission starts getting flares and hard down shifts to first gear because it's getting hot. Any help would be greatly appreciated.
- 4726 Views
Last post by EChem
- 7973 Views
Last post by adrian22
- 486 Views
Last post by Eddystone
- 2497 Views
Last post by WilkinsC30
- 1490 Views
Last post by cfatrat
