Troubles after timing belt change
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
kidsgone
Post by kidsgone »
I have a 2000 S80 non turbo. Last week I had the timing belt changed along with the water pump. The car was running relatively good prior to the change. It had a slight engine knock that remained a bit of a mystery. Now after the timing belt change the engine knock is signifcantly worse. The check engine light instead of just being on steady now blinks at me. I have no power none. Push the peddle to floor and nothing happens. I took the car back. I was told and they changed the spark plugs and something about the evap system was fixed. They found water in the spark plugs. I was wondering if that would be bad gas I did fill up just after timing belt change. No change in performance after changing the plugs out.
I know at least one of the O2 sensors needs to be replaced. They are telling me now that it is O2 sensor. I am wondering if the poor performance is a result of an O2 sensor or something has gone wrong when changing the timing belt. The other thing is that when stopped the check engine light stops blinking. Only when gas is on does it blink.
The question is, could one O2 sensor cause this much trouble and if so can I replace them with a Bosh sensor instead of spending 300 dollars on a Volvo one?
Any assistance is muchly appreciated...
537playing
Year and Model: 2005 S60
Has thanked: 1 time
Been thanked: 5 times
Post by 537playing »
Your timing is off.
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
O2 sensor problems rarely cause misfires in my experience and the timing would need to be wayyyy off for it to do it. Did you get the codes pulled. Go to an autozone, have them pull the codes, write all the numbers down, post them up here and we'll go from there. The blinking CEL means a misfire has been detectced and its easier to detect a misfire when the car is under load, especially if its only one cylinder.
Without the codes, over the internet we are really shooting in the dark. Get the codes :D
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
