Volvo 850 Transmission oil
Brandon
is it true that I should not change my transmission oil since my volv0 850 milage is 225k miles? My local mechanic said that I could do more damage to it than good.
White850Turbo
- Year and Model:
It's tough to say. Is that 225k miles on the original transmission? I changed the transmission fluid on my car at 105k and my transmission went out at 108k. Coincidence? Maybe... maybe not. The reasoning behind this statement made by many mechanics is that over time, a lot of gunk can get built up in the crevices of the transmission. By flushing it, you're flushing a lot of that junk out thus causing slippage or other abnormal behavior. So, I couldn't really tell ya either way. Some mechanics will tell you that it's not going to hurt anything and others will tell you not do it. It's kinda one of those unsolved mystery things. Anyways... If you've managed to get 225k out of that transmission, I see no reason to mess with a good thing.
You should really only need to change it if it is discolored (brown rather than red) or if it smells burnt. I changed out mine at about 110,000 because it was brown and didn't smell quite right. I have had no problems since. I did not have it flushed, I did it the old fashioned way, and Volvo makes that easy by having a drain plug in the transmission pan. I would check the dipstick look closely at the fluid and smell it and then make the determination.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
You actually can get most of it out by going through the process 2 or 3 times and run the torque converter out. It is not as easy as the pump out but its a lot cheaper.
2004 XC70
tina
- Year and Model: 1998 S70, 2001 S40
- Been thanked: 2 times
I had the transmission flushed and filled on my 1994 840 at about 210,000 miles and it was a good thing - smoothed out shifting a bit and the transmission is still going great at 237,000 miles.
Too bad I blew a valve in the engine
see if your tranny's oil has little bits of metal in it, if it does DO NOT CHANGE IT!!! OR YOUR TRANNY WILL FAIL right then. be ready for it to fail soon though.
I need to flush/change mine very soon. 160k, and not counting, the odometer stopped LOL, so i think i have around 170-75
-jaxx
-jaxx
1995 850 T5
...K&N airfilter...upped boost...Joy Life Alarm...
143,000 and some.
143,000 and some.
Luther White
- Year and Model:
Took my 94 850T with 145,000 about a month ago to the dealer to have it flushed, the fluid was a little brown and burnt smelling. Have not had any problems to date. Knock on wood.
Luther White
1994 Volvo 850 Turbo
170,000 miles
170,000 miles
- 2233 Views
Last post by fitz548
- 1315 Views
Last post by alschnertz
- 11 Replies
- 1837 Views
Last post by subzerocarfanatic
- 783 Views
- 2223 Views
Last post by tryingbe
