V70 T5 AND SYNTHETIC OIL
RaymanSean
- Year and Model: V70 XC, 2001
In general no. However, if any of the seals/ gaskets are being helped by build up the use of synthetics may cause the build up to dissolve and allow the gaskets/seals to start leaking. Also do not believe the hype that you can go 10-15 thousand miles between oil changes. I still change my oil every 6K, I am probably overdoing it, but if the engine last longer then it is a good thing.
JRL
- Year and Model: Several
- Been thanked: 16 times
WAY too many miles to convert, use a SEMI-synthetic
- 3121 Views
Last post by Uree
- 53 Replies
- 9545 Views
Last post by sleddriver
- 64 Replies
- 10790 Views
Last post by plumsmooth
- 16 Replies
- 3049 Views
Last post by polskamafia mjl
- 1260 Views
Last post by asummers
