IPD sale Volvo Parts
Did you know? 🤔
ABS fault code 444 problem
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
maora
Year and Model: 440 GLT, 1992
Has thanked: 0
Been thanked: 0
maora
Post by maora » Sun Jan 30, 2011 12:52 am
Hi there,
I can't erase fault code 444 on my ABS ..............I press the button on the ECU and hold it for more than 5 seconds. Nothing happens! The red light is not flashing at all. That means everything is OK, but then when I drive the car, the ABS light on the dash is ON!
Can anybody help with advise ?
Cheers
Stoil
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Re: ABS fault code 444 problem
Post by billofdurham » Sun Jan 30, 2011 11:19 am
How are you getting 4-4-4 on the ABS check? ABS codes are only 2 digits. The attached shows how to read and erase ABS codes.
440 ABS codes.pdf
(367.17 KiB) Downloaded 547 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
yuckuJackD
Year and Model: XC70; S80; S40
Has thanked: 0
Bulgaria
yuckuJackD
Post by yuckuJackD » Sun Jan 30, 2011 5:24 pm
Men, you've registrered in bulgarian forum... why didn't you surch there?!? Or even here - the first treat is: "How to use the On-Board Diagnostic (OBD) unit." In bulgarian forum the picture is the same - on top there is a treat abut the fault codes, puted all together on one place and a explanation of the way to read the codes in Bulgarian. There are members in Burgas who would be happy to give you a hand, another decision... your wish.
This is the treat: Eerror codes 4XX (in Bulgarian)
Good Luck
Translate:
Човече, регистрирал си се в българския форум... защо не си направи труда да прегледаш?!? Или пък тук - първата тема е "How to use the On-Board Diagnostic (OBD) unit.". В българския форум, картинката е аналогична: на първа страница на форума за 4ХХ е темата. Има ги всичките грешки събрани на едно място, както и обяснения как точно се четат. Има клубари в Бургас, който със сигурност ще ти помогнат, също е вариант... ти си знаеш.
Успех
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
SeaMike
Year and Model: 850, 1995
Has thanked: 0
Been thanked: 0
SeaMike
Post by SeaMike » Mon Jan 31, 2011 6:17 pm
billofdurham,
Hey, on a 1995 Volvo 850, this is how we get the code:
http://volvospeed.com/CheckEngine.php
This is where we get the code info from:
http://volvospeed.com/Repair/a3.html
Can you tell me where the "Bridge" terminal connection is that "billofdurham" is talking about in the attached PDF - "440 ABS code""?
I have a 444 error code on my 1995 Volvo 850 "Canadian car"..... Any help on this 444 would greatly, and thank you in advance.
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Tue Feb 01, 2011 11:58 am
Don't confuse your 850 with the Volvo 440 model that is being discussed in this thread. You can read the ABS codes through the socket A3 on your OBD. To read the ABS codes on the 440 it is necessary to bridge sockets 1 and 2 and the codes have only 2 digits. Do not bridge the sockets on the 850 as you may cause damage to the OBD system.
As stated in my reply to maora he can't have a 4-4-4 ABS code on a 440.
Bill.
Previously:
SeaMike
Has thanked: 0
Been thanked: 0
SeaMike
Post by SeaMike » Wed Feb 02, 2011 9:24 am
billofdurham,
Thanks.... I figured it was something like that.
Now I wish I knew how to fix this issue.
It maybe time to take it to Volvo and let them figure it out.
